Separate Filament and B+ Switches
Old 26th July 2012, 05:02 PM   #41
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Dear Kevin: I believe I didn't speak specifically of politic, instead I'm referring to facts of our reality. Politics' and their decisions influence all orders of our lives. Including the things related to audio and music. Even so, if you want to erase, my post, simply do it. No problem for me.
Osvaldo.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 26th July 2012, 05:08 PM   #42
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Yes, politics and religion influence our life, but we don't discuss it here.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 26th July 2012, 05:18 PM   #43
Once, I believe I'm not discussing nothing, only narrating a fact of the reality. So real as that 2 + 2 is 4.
Here, in Argentina, it is very difficult to buy some electronic (and much other) materials, by a politic decision. I don't tell nothing if it is good or not. Only a fact.
Sorry to all other members of the forum.
Old 27th July 2012, 03:19 AM   #44
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Osvaldo, The reason for the rule on politics and religion (among others) is because these topics tend to bring about very polar views which in the past have lead to lot's of unpleasentness.
You are free to discuss the difficulties in obtaining parts, the throw away society we live in today etc, just leave the political comments out and you will be fine.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 27th July 2012, 04:31 AM   #45
Conrad Hoffman is offline Conrad Hoffman  United States
Reading the old Radiotron handbook, which I think can be downloaded, they have quite a lot on the subject of when to turn on the B+ and what should happen in "standby". More than I wanted to know! There are even times when a partial voltage should be applied in preference to zero or full. There are other times when it's best to just shut everything off. Every old Dynaco and other tube thing I used to own had but a single power switch. Most every tube guitar amp has two switches, one for power and one for standby.
I may be barking up the wrong tree, but at least I'm barking!
Old 27th July 2012, 06:05 AM   #46
Wavebourn's Avatar
The rumor is, first standby switch was added because electroytics could explode without load and sag. Then guitarists liked them because they could switch off the sound before unplugging the guitar leaving the stage, but coming back they could switch it on immediately and start playing.
Old 27th July 2012, 09:23 AM   #47
asterkao is offline asterkao  Taiwan
asterkao's Avatar
Originally Posted by Vinylsavor View Post
Hi!
Wire the two switches such that the filament switch not only switches the filament transformers, but also applies the mains voltage to the HV switch. This avoids that the HV can be accidentally switched on without filament voltage.
Best regards
Thomas
like this .
PL519 + 6JM6 PSE
meanwhile amplifier could switching to PL519 or 6JM6 operation standalone.
Old 2nd October 2012, 02:20 PM   #48
Bigun is offline Bigun  Canada
Bigun's Avatar
I found this somewhere:
"If you want to do 2 switches, I recommend you use 2 double-pole switches.
Wire a pole from each in series to feed the B+ power.
Wire a pole from each in parallel to feed the heaters.
No matter which order you hit the switches, one switch on gives you heater power, and the B+ comes on when both switches are on. There is no combination that gives you B+ without heaters on."
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 2nd October 2012, 11:07 PM   #49
ratbagp is offline ratbagp  United States
If you go half way down this web page you will find a diagram for a dual DPDT solution.
Audio ratbag: Tube Taster Linestage
You might get a laugh along the way.
ray
Old 3rd October 2012, 04:29 AM   #50
jackomancy is offline jackomancy  New Zealand
Default A picture worth a thousand words....
To expand the theme, here's a pic of the foregoing good idea....
Cheers!
Separate Filament and B+ SwitchesHide this!Advertise here!
Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches) tiefbassuebertr Parts 19 25th November 2017 06:18 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
How to separate E from I in transformer? mad_z Parts 15 1st November 2006 08:20 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 16th April 2004 11:33 PM
