Separate Filament and B+ Switches
Old 24th July 2012, 08:35 PM   #21
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
Wire the two switches such that the filament switch not only switches the filament transformers, but also applies the mains voltage to the HV switch. This avoids that the HV can be accidentally switched on without filament voltage.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 24th July 2012, 08:37 PM   #22
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by Osvaldo de Banfield View Post
I personally stronger dislike mixin' sand and glass. SS for SS and VTR for tube amp.
I personally strongly like to mix whatever needs to get better results. And can't understand why somebody would want to set meaningless boundaries.
The Devil is not so terrible as his math model is!
Old 24th July 2012, 08:42 PM   #23
Wavebourn's Avatar
Looks like it is the best solution of the initial problem. Such approach was used in radar stations. Also, antenna switches (actually, doors between waveguides) had additional switches to prevent powering on high voltage source until it switches properly. It was the requirements for magnetrons, to have hot emitting cathode, and properly tuned output, before applying anode voltage. However, I don't understand why it would be needed for audio amps, but since it is a hobby everyone is free to go for own personal goals.
Old 24th July 2012, 08:54 PM   #24
Magz is offline Magz  United States
Hi!
Best regards
Thomas
Good Idea! Thanks, Thomas!
Old 24th July 2012, 08:56 PM   #25
In this case the answer is...because I want to!
Maybe I have a switch fetish.
Old 24th July 2012, 09:00 PM   #26
Wavebourn's Avatar
Please don't use "the brand of a switch with 4 letters that start with Ni."
Old 24th July 2012, 09:15 PM   #27
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
Two switches are the only right way to power on a tube amp, it is less expensive and simpler too, I fell afraid when I see just a sole switch in a amp.
Temporized relay, clocks etc are more expensive and prone to fail with age, a 2șclass solution, some tubes had long heating time as 6C33(600 seconds) for the cathode to reach the proper temperature, a 600 seconds timer is too long.
Ralph Karsten use two switches in the Atma-Sphere amps and its run alot of tubes.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 24th July 2012, 09:19 PM   #28
Davec113 is offline Davec113  United States
Davec113's Avatar
Hi!
Best regards
Thomas
Great idea! I will rewire my preamp this way.
Old 24th July 2012, 10:54 PM   #29
Originally Posted by mvd View Post
Or building the rectifier with damper-diodes wich give you a nice warm-up time from 20 to 30 seconds.
For a preamp the duo-diode 6BY5 from RCA would be a good choice.
Best regards
Michael
I have a couple 6BY5s, but I'm leaning toward an all DH preamp. Having two switches gives more flexibility.
Old 24th July 2012, 10:59 PM   #30
DF96 is offline DF96  England
Nonsense. In most cases one switch with no sequencing at all is the correct way to power an amp. If sequencing is needed (rare with normal audio valves) then it should be automatic. If you are "afraid" then use proper interlocking so the switching is failsafe. Two switches is either a DIY fad (it's a free world) or a marketing ploy for ignorant people. Why not add a third switch for the input signal?
Separate Filament and B+ SwitchesHide this!Advertise here!
Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches) tiefbassuebertr Parts 16 4th August 2017 02:31 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 02:06 PM
How to separate E from I in transformer? mad_z Parts 15 1st November 2006 09:20 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 17th April 2004 12:33 AM
Copyright ©1999-2017 diyAudio
