Separate Filament and B+ Switches - Page 2 - diyAudio
Old 24th July 2012, 06:48 PM   #11
mvd is offline mvd  Germany
mvd's Avatar
Originally Posted by DF96 View Post
Why not have one switch? If you need sequencing (which I doubt) then this should be automatic, otherwise you will sometimes get it wrong.
Maybe one can find a Mains-Switch wich has 3 Positions, like "Off", "Preheat" and "On".
Building it in this way nothing can go wrong.
There are many round-switches wich have more than only 2 positions.
Best regards
Michael
Old 24th July 2012, 06:50 PM   #12
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Best regards
Michael
Excellent idea !!!
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 24th July 2012, 06:57 PM   #13
Like this one - New AC Selector Switch ? Just noticed the out of stock.
Hey is for horses.
Old 24th July 2012, 07:09 PM   #14
mvd's Avatar
Yes, this looks nice.
BUT, i think it has to be a "make before break" switch, the same principle as in a stepped attenuator. Otherwise the heater voltage will have a break for a few milliseconds while you switch from "Preheat" to "On".
Best regards
Michael
Now playing: New Magma box "Köhnzert Zünd"
Old 24th July 2012, 07:13 PM   #15
Magz is offline Magz  United States
Originally Posted by Wavebourn View Post
Why not a car with 2 steering wheels, one per a front wheel?
My wife would like that.
Old 24th July 2012, 07:18 PM   #16
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
So, 3-position switch would not work. You definitely need 2 separate switches. Like missile launch stations had 2 buttons locked each by own key. By the way, I used a key lock in one of my amp prototypes. The amp can be locked so kids can't touch hot tubes, break glass, be electrocuted by 800V on anodes.
The Devil is not so terrible as his math model is!
Old 24th July 2012, 07:18 PM   #17
And what about a temporized relay?
Old 24th July 2012, 07:24 PM   #18
mvd's Avatar
Or building the rectifier with damper-diodes wich give you a nice warm-up time from 20 to 30 seconds.
For a preamp the duo-diode 6BY5 from RCA would be a good choice.
Best regards
Michael
Old 24th July 2012, 07:30 PM   #19
Wavebourn's Avatar
Semiconductors are more convenient than tubes for power supplies. For slow start I use voltage stabilizers with positive feedback by current that works until the regulator starts stabilizing voltage. It brings up voltage very slowly with no load. When tubes are hot and start drawing current it increases voltage with higher speed, but slow enough to avoid surge currents due to initial charging capacitors in the amp. Smoothly and graciously.
Old 24th July 2012, 07:32 PM   #20
I personally stronger dislike mixin' sand and glass. SS for SS and VTR for tube amp. In my regenerative AM receiver, ss diodes irradiates harmonics. A pretty 6X4 was the solution.
Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches) tiefbassuebertr Parts 15 3rd December 2015 08:34 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
How to separate E from I in transformer? mad_z Parts 15 1st November 2006 08:20 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 16th April 2004 11:33 PM
Copyright ©1999-2017 diyAudio
