Hello Everyone,
Any suggestions on the thought of using a 12AY7 preamp tube instead of the 12AX7 originally included in the schematic? I've gotten to the point where I can figure out the values for the load resistor and the cathode resistor from the curves but I'm not sure how this circuit works exactly? The schematic is figure 3 on page 4 of the Dynaco transformer catalog which is too large to upload. The 12AY7 has a lower MU but more amperage. And from my research is closer to the kind of sound I want from this amp. Thanks for any help you could povide, kevin |
#2 |
Thanks anyway. I already figured it out.
| preamp supply LOW power LOW noise LOW cost | drdagor | Power Supplies | 1 | 13th September 2010 11:39 PM |
| Dynaco ST35 power? | KJ2005 | Tubes / Valves | 15 | 15th August 2008 01:47 PM |
| Need work done on a dynaco power amp | ag2217 | Tubes / Valves | 1 | 6th August 2007 11:35 PM |
| Extremely low power and low loss transformers | percy | Tubes / Valves | 12 | 23rd February 2005 10:30 AM |
| dynaco pas3 power supply | SBIRO | Tubes / Valves | 2 | 26th June 2003 06:19 PM |
