Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
Thread Tools
Old 18th October 2003, 12:06 PM   #1
Default Tube regulators and noise ?
I just bought most of the parts for a little differential line stage that needs 140-150 vdc at 60 ma. Would a pair of oa3,s have less noise than say a 2 75v 10w zeners with a good 100uf bypass cap. Or could I follow the oa3,s with say a 10 ohm resistor and a good 100 uf cap. and not have it go into osilation?
Thanks,
woody
Old 18th October 2003, 04:52 PM   #2
45guy is offline 45guy
Default Try an OD3
Hi Woody,
Try an OD3 with no caps, or something very small after it. That tube works well in my E80CC linestage, actually 2 of them in series for 300v B+. They are nice and quiet and I love the glow! Can you get 185-195v out of your PT before the tubes? You are correct that a 100uF after the VR tube will cause problems. Try not to add any more resistance in the PS than you really have to. The current set resistor won't be noticable since the VR tube/s are shunts and keep impedance low. Hey, that gives me an idea...
More later on the idea part.
Tom
Old 18th October 2003, 05:32 PM   #3
I don't find vr tubes noisy either but they sure make things sound good.
Old 18th October 2003, 05:54 PM   #4
analog_sa's Avatar
The VR tubes are a lot more capricious than zeners to get working but they sure sound better. No idea about the noise; i use several in a phono stage with no noise issues.
Old 18th October 2003, 06:18 PM   #5
diyAudio Senior Member
fdegrove's Avatar
Most VR tubes oscillate when they have a shunt cap bigger than 0.1µF across them.
I never noticed any noise issues but yes, they can be a little harder to get working but that's due to the fact that a lot of people do not read through the datasheet properly.
Other than that they just work and work and work...
Frank
Old 18th October 2003, 06:57 PM   #6
6BG6GA is offline 6BG6GA
6BG6GA's Avatar
I have used VR regulators thanks to Frank's help. In my 5687 line stage it sounds much better and the difference is very apparent. In my 5692 line stage I use a set of 0D3 and 0B3's for each channel. I never tried this one without the VR's as I am sold on them. As stated in other post not more than .1 cap.
Thread Tools
tube noise Gaffa Tubes / Valves 8 10th May 2008 04:28 AM
Low Noise 3 Leg Voltage Regulators dsavitsk Parts 2 10th July 2007 02:49 AM
Reducing noise in voltage regulators Sud Solid State 114 28th November 2006 06:47 AM
Tube VS SS voltage regulators - any advantages? Wavebourn Tubes / Valves 14 25th October 2006 05:47 AM
Simple and Low noise Pre-regulators for DAC machinow Digital Source 2 10th September 2004 01:04 PM
Page generated in 0.07007790 seconds (74.81% PHP - 25.19% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
