First Time tube amp - need help - diyAudio
Old 18th October 2003, 04:06 AM   #1
Default First Time tube amp - need help
I would really like to build a tube amplifer but really know nothing about them. The tube I have is a GE, and on the glass it has "251.6" and "GT". On the black part of it, it has faded nubmers that I think are "58.43" and "C88-3" Can I use this tube as an amplifier. I also have a 13CW4.
If they will work, How do I use them? Does anyobody have a schematic for it? Are they simple to build and operate? Do I have to worry about heat? What kind of power supply is needed (voltage, amps, AC or DC, single or split)? And, finally, speaker wires shorting?
Thanks if anybody can help at all, Mike
Old 18th October 2003, 06:23 AM   #2
I can't help you with the tube identification
but the tube i should be able to help with the schematic
you check out my website www.geocities.com/nickchua81
to get a rough idea of a tube amp
than from there figure the schematic for the tube you have
i am speculating the 13cw4 is nuvistor. Is it very small compared to a 9pin. If so then you got yourself a voltage amp then. I think Joel made a nuvistor amp drving el84 i think .
Old 18th October 2003, 06:38 AM   #3
45guy is offline 45guy  United States
Default 25L6-GT
Ahhh, I think you have a 25L6-GT there. You could build a simple little SE amp that should put out just over 2 watts. I think it wouldn't take much to drive it. I'll drop you a email...I have lots of parts here in the shop!
Tom
Old 18th October 2003, 08:00 AM   #4
Brett's Avatar
Some questions;
- Do you know the tubes are good, ie did they come from a knowledgable/reputable source?
- Do you want to simply experiment with some tubes, or would you looking to build an amplifier that you can use, long term, in your system soon?
- How much power do you need?
- Budget?
- What speakers are you / are you intending to, interface with?
In a tube amp, a large part of the budget can go towards the transformers, so if you want something to use and keep, then I wouldn't spend money to optimise around a 25L6. As an experimenter / learning amp with surplus iron it would be fine. But why not build something to use and enjoy? If you're starting from scratch and have to purchase everything anyway build the best you can within your budget; the learning experience will be the same or better.
My suggestion would be something like the Magnavox 6BQ5 PP amps with Hammond (or good second hand) output transformers. About 15W/ch and good sounding too. Not hard to build, complicated or expensive.
Old 18th October 2003, 08:59 AM   #5
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
its a 25L6GT, a radio output tube circa 1940. up to a max of 4~5w in class A. (2w is 125/125v, but the goofs know no better ;
wake me up tomorrow mornng and i can help with a schema
sorry guys.. im just buggin' ya
Old 18th October 2003, 12:59 PM   #6
A person I know who worked for Motorola in their electronics area gave me all of his parts when he retired, and one of them is a metal plate with 2 potentiometers, 1 a switched one, a small transformer that is just labeled "TR-118" "798 724" It has some wires, caps and resistores connected to the tube socket in p2p. Then, there is a 150V capacitor that has many wires and has 40, 30 and 20mfd and the tube. Out of the holes on the top of the metal are 4 cut off wires. Also on the botttom there ius this grey metal thing that has a screw in the bottom, a round shaft up the middle and 6 square things that look like fins.
Also, after the fact that the tube is a 251L6 was pointed out, i looked at it again and realized that the thing i had thought was the . was really the bottom of the L.
I would like to use this tube, to save some money, and also, because I just want a simple to build first-time amplifier. I don't need anything fancy. I have been using gainclones for a while now, and wanted to try something different.
As I said, I don't know too much about tubes. What kind of impedences can they drive? Also, how much power is needed to operate it? I remember reading that tubes work best for bass and midrange. Does this mean that ijt can drive a subwoofer? Possibly better than a 3886 gainclone?
Thanks for the help, Mike
Old 18th October 2003, 04:28 PM   #7
Default Here's my email response
I thought I would post this so others know my thoughts and what we have discussed-
Hi Mike,
Like Brett said, the 25L6 is not a tube that I would use to build an amp. And as Colt45 said, you are not going to get much power from just one of these....but that's not what it's all about anyway! You really don't see this tube used much at all. The parts you were given are likely not good anymore. Caps like the multisection one you have can dry out, rendering them useless for filtering. The metal thing with the fins is a selenium rectifier. They were used in many Dynaco amps and its the first part that most folks replace when restoring an amp. I have read that they can explode when they do go bad, just like caps will if you exceed the voltage rating. I'm betting the transformer is the output transformer and this amp was run straight from the line voltage. It's not a safe way to do things since you are not isolated from the current out of the wall socket. That was done many years ago to cut costs, the cost of the power transformer. That's why you see many tubes used in TVs and old console radios that have heater voltages that can be run in series from 115 volts line in. 25, 30, and 50 volt heaters were far more common back then. I don't think you could ever find insurance coverage if you marketed a product built like that these days.
Most tube amps that you see built these days operate on B+ voltages much higher than your gainclone, like 200-500 volts neighborhood. And in the tube world, power costs $$. But it isn't power that many of us are after. You will read about many loonies, myself included, that spend a great deal of time and money on flea power directly heated triode amps with outputs in the 1-8 watt range. If you want to keep costs down on your first project, go with something simple, like a linestage. It should be a great buffer for you gainclone amp. Maybe someone on the DIYAudio BBS can suggest a nice simple design that runs on a B+ of about 165v and low current. That way I could send you the parts you would need, sans volume pot, jacks and, chassis. It's a great way to get started without dropping much $$. I think I spent around $600 on my first tube amp project (a simple 2A3) and it sounded pretty poor in comparison to one of the entry level kits out there. It was an expensive way to find out that I needed to learn more before calling to order parts!
Let me know what you decide. We'll set you up with something to play with!
Tom
Old 24th October 2003, 04:13 AM   #8
PRR is offline PRR  United States
PRR's Avatar
And was glad to get rid of "that junk".
I don't mean to laugh at you. You want to learn, and that's all good.
But I will offer a similar story. Pretend you never had a car. A friend gives you a carb from a 1953 Nash, a wheel from a 1967 Fiat, a seat from a 1987 Chevy, and some other car parts you don't know what they are. You want to know if you can build a car, and you probably mean "a good car", not just "something that moves".
You have a real odd-lot of tube-radio parts, some fairly specialized (the 25L6 is specialized for really cheap radios), all in unknown condition (loose parts from a tinkerer's bins are very often dead or half-dead parts left behind from repairs). You are missing some important parts to do anything useful. While a gainclone chip is nearly a complete amplifier in one blob, a tube is very much a "part", and you need a lot more parts before it does you any good.
It Varies. Speaking very generally, you need a low-volt high-amp supply, like 6V 2A, to warm-up the "heaters". A tube won't do anything until its heater is red-hot. But the heater is just heat to loosen some electrons. You need a high-volt low-current, like 250V 0.050A, DC supply to suck those electrons through a load and do something useful. Yes, this is a real shock hazard and yes, tube gear runs very hot compared to most transistor/chip stuff. And then, because tubes are high-volt low-current and most loads are low-volt high-current, you need an audio transformer to make them work together. This transformer is often as big and more expensive than the power transformer.
I could sketch-up a 25L6 amplifier to make a watt or so. But you need lots more parts. While some of the parts you have might work, the general impression I get is that these are cheap parts and why go to a lot of trouble to make an amp that will sound cheap and give "tube amps" a bad name? By the time you buy good parts like power and output transformer and socket(s), there is no point in saving that $0.50 25L6 when a $15 tube will not only work better but possibly be easier to build. (The 26L6 has an unusual heater voltage, and you will need at least one more tube, which probably won't be 25V heater, so already your heater supply is getting complicated.)
Here is a simple one-tube amplifier, intended for headphones but will make a good sound in a loudspeaker. You probably won't understand the whole essay at first, and I don't say this is any great design, but it was intended to be about as simple and inexpensive as a tube audio power amplifier can be. It will give you an overall picture of what a tube amp project looks like. You can find far better projects on the web. Most of them assume you have some idea what you are doing already; you will need to read a bunch of them to get your bearings.
> Does this mean that it can drive a subwoofer? Possibly better than a 3886 gainclone?
Nobody is born knowing this stuff.... but you do have some learning ahead of you.
Most of the things we call subwoofers need 100 watts or more to get high output. I happen to remember (took a while to learn all this) that the 25L6 was designed to make just 1 watt, enough for a kitchen radio. Colt45 can maybe get 4 watts out of one, but I hope he gets them cheap because I would expect them to die fast with that kind of abuse. (Yes, 25L6es are pretty cheap, a glut on the market, since many millions were used in the 1940s and 1950s for many kitchen radios.) You can get more than twice the power with two tubes, but to get subwoofer level power, you would need a whole bucket of 25L6 and it really makes more sense to start from a bigger tube. And any speaker amplifier needs a special output transformer, a rather large costly one for subwoofer duty.
??? You can read many things; not all of them are true. You can't even believe all that I tell you. Listen to everything, but only believe things that make sense all-together.
Tubes are good far past the audible range. If I had to, I could make a CB transmitter from your 25L6 (and a heck of a lot more parts), running at 27MHz (that's 27,000KHz). A lot depends on the output transformer. Maybe what they mean is: it is hard to make an output transformer for audio that is good both at deep-bass and at high-treble. It is a problem, but can be solved (money helps).
There is a $150 stereo tube-amp kit floating around. It isn't top-spec, but it will make a nice noise (and quite different from the gainclone). It would be a way to get started, without being stalled by design and part-selection hassles, and it does give great bang for the buck. See if you like working with and listening to tubes (allow for the fact that $140 does not buy great transformers or capacitors), then you can judge if you want to try something better (more expensive).
Oh: you want to put that 25L6 to "good use"? Poke the pins with an ohm meter: only two of them will show about 50 or 100 Ω conductivity. Wire those to a 24V 0.2A (AC or DC) power supply. The heater in the center of the tube will glow red. Looks cool in a dark room. You "should" use a socket, but if you didn't get one then I would just tack-solder wires to a 25L6. Tube are precious, you shouldn't blob-up the pins, but a junkbox 25L6 is about the least precious tube there is.
Old 24th October 2003, 05:32 AM   #9
PRR's Avatar
Uh, I forgot my memory is failing with age....
To light-up the heater in a 25L6 you need 0.3 Amps at 24-25 Volts, not what I said.
And 25L6 can do 2 watts in a cheap radio, and is rated 3.8 watts (at a higher supply voltage than any cheap radio used). Clearly Colt45 can be getting 4-5 watts without gross abuse that would reduce tube life enough to care about.
We almost always saw them working more like 1 watt, because a few pennies saved in radio parts was worth more than another watt of power in the kitchen. But now that I check specs (as I should have done), I recall the 25L6 and its twin 50L6 working at several watts in living-room radios, and in pairs making even 7-10 watts in small movie projectors.
And for lurkers: no, a 25L6, 35L6, or 50L6 isn't a variant 6L6. They probably did pick "L" to resonate with the aura of the mighty 6L6, and because they do come out of the same research, but the 6L6 is 360V 19W, while the radio xxL6 tubes were 200V 10W.
Old 24th October 2003, 06:42 AM   #10
Default Very well put!
Thanks PRR,
You filled in the many holes in my reply. I hope he has not given up hope about diy tube endeavors. I hope he understands that it's not about wattage, it's about music....and in my case, learning, tinkering, and being creative.
Tom
The more I learn, the more questions I have.
First time DIY tube squiggy Tubes / Valves 2 15th January 2007 12:52 AM
First time tube jitters... JojoD818 Tubes / Valves 48 11th February 2004 04:49 AM
First Time Tube Amp cummic Tubes / Valves 7 9th July 2003 12:34 PM
First time building a tube amp: Help please JAZZ2250 Tubes / Valves 36 28th June 2003 10:37 PM
First time Tube Amp Milzie Tubes / Valves 13 5th December 2002 07:28 PM
Copyright 1999-2017 diyAudio
