diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Mystery tubes on FB? (http://www.diyaudio.com/forums/tubes-valves/216450-mystery-tubes-fb.html)
jackinnj 19th July 2012 01:04 AM
1 Attachment(s)
OK, I've seen a lot of tubes but not miniatures with plate caps -- a friend posted this pic on FB -- can anyone identify:
radiotron 19th July 2012 01:53 AM
the miniature with top cap is a EL81 horizontal sweep tube for portable B&W TVs
Colt45 19th July 2012 08:49 AM
1 Attachment(s)
Yeah, presumably some sort of small sweep or so.
There was quite a few dampers in this format too, 6AF3 being one that comes to mind.
Although, technically... these have cathode caps, not plate :p
7N7 19th July 2012 09:14 AM
European TV "Efficiency" (Damper) diodes such as EY82/PY82 are another possibility. With EY82 the top cap is the anode.
7N7
hidnplayr 19th July 2012 09:39 AM
The internal construction of this tube shouts PL81/EL81.
disco 19th July 2012 09:50 AM
From 1955 until 1965 EL81 was used in PA and early hifi amplifiers (from Philips Germany if I'm right). A push pull pair produces 20W of audio power.
hidnplayr 19th July 2012 10:10 AM
Originally Posted by disco (http://www.diyaudio.com/forums/tubes-valves/216450-mystery-tubes-fb-post3097456.html#post3097456)
20W yes, in class B, I believe most of us here do not call that "HiFi" ;)
disco 19th July 2012 10:19 AM
The Philips AG9006 was an early OTL, used on 1200 ohm loudspeakers. Very rare these days and rather unaffordable then ;)
DF96 19th July 2012 10:48 AM
Yes, looks like a PL81 (or maybe EL81). PL81 and PY81 were very common in European black&white TV sets. PY82 is a supply rectifier, with no top cap.
Probably rare in the US is the Brimar 6BS7, a miniature low noise pentode with a top cap for the grid. Probably a variant of the 6BR7.
Tubelab_com 19th July 2012 12:42 PM
I have an EL804. It is a 6CW5/EL86 with a plate cap. It also says Made in USA.
Resources saved on this page: MySQL 18.75%
