Mystery tubes on FB?
Old 19th July 2012, 12:57 PM   #11
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Originally Posted by DF96 View Post
Yes, looks like a PL81 (or maybe EL81). PL81 and PY81 were very common in European black&white TV sets. PY82 is a supply rectifier, with no top cap.
Probably rare in the US is the Brimar 6BS7, a miniature low noise pentode with a top cap for the grid. Probably a variant of the 6BR7.
Philips, it seems were a little confused on the subject of top-cap for the PY82; the line drawing shows the anode connection at the top of the valve, whilst the base diagram shows anode at pin 9!
I had a Marconi valve voltmeter that was fitted with 6BS7 (or 6BS8?) with grid top caps. I converted my Quad IIs to run 6BR7s as suggested by Chris Beeching. Very satisfactory.
7N7
Plug them in and light them up
Old 19th July 2012, 01:26 PM   #12
DF96 is offline DF96  England
The data sheet you linked to shows it quite clearly as a single-ended valve. The only thing on top is the glass sealoff pip.
Old 19th July 2012, 02:28 PM   #13
miklos is online now miklos  Hungary
miklos's Avatar
Did you know the EL81 is completely different from the E81L?
miklos
Old 19th July 2012, 03:03 PM   #14
7N7's Avatar
Yes that's right - in the representation of the envelope, but above there is a line drawing showing the anode connection at the top.
7N7
Old 19th July 2012, 11:08 PM   #15
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
7N7
? Are you referring to the tube schematic symbol? That's as standard a symbol as you can find; it doesn't imply a top cap.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 19th July 2012, 11:11 PM   #16
7N7's Avatar
OK my mistake, thanks, a bit over-wrought I think today
7N7
Mystery tubes on FB?Hide this!Advertise here!
F3 and Fb significance Shpilev Subwoofers 18 11th July 2012 01:41 PM
MYSTERY METAL TUBES B-1532 Electron Ron Tubes / Valves 0 2nd April 2012 02:26 AM
Fb vs F3 fantfool Multi-Way 2 3rd March 2010 05:31 AM
Output transformer and FB Ragnwald Tubes / Valves 4 8th May 2008 09:45 PM
Philips FB-860 ManUtd Multi-Way 1 5th September 2004 03:23 AM
