Any Cheap Tube-amp kits out there - diyAudio
Old 17th October 2003, 04:54 PM   #1
Account Disabled
Default Any Cheap Tube-amp kits out there
I am looking for a cheap tube-amp to expirament. It will be used to drive seas millenium tweeters (6 ohm) as part of an active XO, used at 2200Hz and above, so it does not need to have high output power.
Thanks,
Paul Hilgeman
Old 18th October 2003, 11:12 AM   #2
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default Inexpensive Amp
Antique Electronic Supply has 2 kits theK-501 (89.50) and K-502(139.50) which are 8 watts mono or stereo.
or
Check this out
http://s5electronics.com/gpage1.html
Old 18th October 2003, 04:41 PM   #3
how built something along the lines of the el34 or a 2a3 at my website
www.geocities.com/nickchua81
power for el34 would be more than 2a3 though
but el34 cost would be much cheaper as a begineers amp. IDHP are cheaper to implement, hum from heater is no a common thing.
of course you could run the el34 into pentode or ultralinear but i don't recommend it for tweeter action.
I would personnaly recommend se, as tweeters don't require much power hence triode are the way to go
mail me if you like to ask something or work something out
i have not work out the cost yet however
Old 18th October 2003, 06:03 PM   #4
HDTVman is offline HDTVman  United States
I have built the K-502 MikeT suggested and it is a very nice little amp for the money. It lends itself well to modifing. Some good parts make this simple design sound very good. Is it the be all end all amp of the world, no, but it is a nice amp.
LaterBZ
What ever makes the tunes flow
Old 19th October 2003, 10:19 PM   #5
Account Disabled
Thanks for all of the replies guys, I will look into building one of these and seeing how I like it. It never really is a problem to have spare amplifiers laying around is it?
HDTV man, where in chicago do you live?
I will be moving to Lake Bluff in 3 weeks.
Old 23rd October 2003, 12:39 PM   #6
Pete Millett has a lot of info on low power amps
http://www.pmillett.addr.com
Simplest I've seen is the 6EM7
http://www.valvediy.com/6em7pppg1.html
http://www.diyzone.net/diy/references/tube/6em7PP.pdf
Old 23rd October 2003, 05:28 PM   #7
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Have a very close look at:
World Audio Design
Look at their KEL84 or the Kecl82.
Gaz
Cheap guitar amp kits? leadbelly Instruments and Amps 7 25th July 2008 04:03 PM
Looking for cheap SPDIF DAC kits? theAnonymous1 Digital Source 1 9th June 2006 04:59 PM
Newbie question on cheap amp kits mastiff Tubes / Valves 14 8th August 2002 03:45 PM
Copyright 1999-2017 diyAudio
