Old 18th July 2012, 07:30 PM   #1
Default Mikael Abdellah KT88 SE with Cornet2
Hello All,
I am going to be building the Mikael Abdellah SE KT88 amp soon. I plan to use the octal 6sn7 in place of the 6n1p, this will lower the gain. I also plan to build a octal cornet phono amp after (can you tell I have a fondness for octal tubes). My question, will there be enough gain with just the Cornet into the SE KT88 or would i need to have a preamp between the two? I would like to avoid a third piece of hardware but if need be, what would be a good DIY option for this?
Also, in the time between the completion of the KT88 amp and the start of the cornet, i would like to run a budget SS phono amp into the KT88 amp, any suggestions?
thanks much,
-david
Mikael‑Abdellah‑SE‑KT88 Bias & Voltage readings Help? bigaudioscotto Tubes / Valves 49 7th July 2012 11:44 AM
Improvements for the Mikael Abdellah KT88??? 69CamaroSS396 Tubes / Valves 42 16th December 2009 01:58 AM
new build - abdellah SE KT88 vince76 Tubes / Valves 19 31st July 2009 10:07 PM
Mikael Abdellah SE KT88 ideas and questions kacernator Tubes / Valves 6 14th January 2008 01:09 PM
Looking for KT88 Amplifier Schematic by Mikael Abdellah jduffy Tubes / Valves 6 5th April 2007 09:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
