NOS Neglected Hi-End Audio Tube
Old 7th October 2012, 07:21 AM   #11
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi Steve,
these tubes are not the same. The 5694 cannot be regarded as general alternative to the 6SN7! It can degrade the performance if the circuit around if that cannot work well with the much higher plate resistance. The higher mu can be a benefit in some circuits but also a disadvantage in others.
Also important to note that they have a different pinout. Otherweise unexperienced readers might just try to plug these into their 6SN7 sockets.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 7th October 2012, 08:54 AM   #12
v4lve lover is offline v4lve lover  Netherlands
this guy is just trying to get His merchandise sold... Great bargain @ 100Usd/tube, joker
there is stuff that is sold for 50 cents a valve that can really be called a bargain..
Old 7th October 2012, 11:50 AM   #13
mctavish is offline mctavish  Austria
''Not being sentimental or indecisive, my barely used quintet quickly fetched $1,000 on the slightly used NOS market.''
What is the slightly used New-Old-Stock market?
No, really?
When did ''NEW'' stop meaning not used?
Old 14th October 2012, 02:17 AM   #14
Roymercer is offline Roymercer  United States
Thank you Thomas. Understood and point taken. Yes, just like the 6F8G an adaptor must be used. The difference of course is the specs are virtually the same as a 6SN7.
That is OK because I know that for me, in my Oppo BDP-95 w/Modwright mod, I have run these tubes for hundreds of hours and they are the cream of the crop in my set-up.
Old 14th October 2012, 02:18 AM   #15
Is there a way to be emailed upon activity on a particular thread? Thanks!
Old 14th October 2012, 03:23 AM   #16
Pano is offline Pano  United States
Pano's Avatar
Look up top where it says "Thread Tools" and click "Subscribe". You should then get email notifications.
Old 14th October 2012, 03:07 PM   #17
vconsumer is offline vconsumer  United States
Also consider the 7N7 tube. A loctal version of the 6SN7 that sounds quite good.
Old 14th October 2012, 03:14 PM   #18
kevinkr's Avatar
On the recommendation for the 7N7, it is the loktal equivalent of early 6SN7GT and because of the loktal base it is still far cheaper than comparable vintage 6SN7.. Don't get fooled by the "7" it is in fact a standard 6.3V filament type. IMVLE there are no bad 7N7..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th October 2012, 03:20 PM   #19
Vinylsavor's Avatar
Hi!
+1 on the 7N7 recommendation! Contrary to the tube mentioned above the 7N7 is electrically equivalent and only needs the socket change or adaptor
Best regards
Thomas
NOS Neglected Hi-End Audio TubeHide this!Advertise here!
Is high-end audio just lots of gimmicks and high price tags ?? Trevor White Everything Else 497 20th June 2011 10:07 PM
High-end NOS DAC Kit with PCM1704 up to 24bit/192KHz Eric Juaneda Vendor's Bazaar 6 24th September 2010 05:47 PM
pair of NOS Mullard CV4003's (high end 12AU7) Glowbug Swap Meet 0 28th November 2006 12:33 AM
