My Russian SET
My Russian SET
Old 26th August 2012, 02:30 AM   #41
c1ferrari is offline c1ferrari
Dear Tony,
Congratulations
I am awestruck by your knowledge and ability
Best regards,
Sam
Vbr,
Sam
Old 28th October 2012, 12:17 PM   #42
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
My Russian SET
Originally Posted by c1ferrari View Post
Dear Tony,
Congratulations
Best regards,
Sam
thanks...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 28th October 2012, 12:18 PM   #43
TonyTecson's Avatar
My Russian SET
with fuses installed, power to the output traffo and output tubes are complete....the 3 minute delay timer shorts out the 12k/5W soft start resistor...this resistor is in series with the main B+ ac supply....voltages ramps up to about 100 volts and stays there until the 3 minute timing period is reached, this protects the output tube from thermal run-away, at the same time that the plate B+ is ramping up, the negative bias voltage is likewise ramping up and settles to a value around -75 volts....these steps ensures successful turn on of the amp....
at the end of the 3 minute timing period, the relay closes and the 12k resistor is shorted out thus the B+ finally ramps up to around 210volts dc.....it takes another 5 minutes for the plate current to reach about 200mA....i recommend to wait for 10 minutes before music is played to give time for the amp to settle down to business....
i set the bias pots for this plate current level and bias drift was observed...i am happy to report that drifts were minimal and after 2 hours the bias current actually goes down a bit by around 10mA....this is normal as plate voltages in triodes have an effect on plate currents.....
i also observed that bias changes were caused by changes in line voltages.....
set-up for final adjustment to bias the output tubes.....
with my power meter monitoring the ac input to the amp, power factor was at 92%.....
total watts measured at 218watts...
line current....
thermal scan of the bulb at socket side underneath the chassis, i have installed fans running of 7 volts dc to move a bit of air underneath the amp when bottom plates are installed...
Old 28th October 2012, 06:10 PM   #44
costis_n is offline costis_n  Greece
Made with all the rules of good behavior, I have to say.
Congratulations.
Old 28th October 2012, 07:48 PM   #45
Davec113 is offline Davec113  United States
Davec113's Avatar
Wow, nice! Thanks for sharing.
Old 29th October 2012, 01:59 AM   #46
TonyTecson's Avatar
My Russian SET
thanks guys, i am excited about this design....the final operating points and power consumption predictions were spot on, computed versus actual.......i am happy....
the power trafffo is a little warm even after 3 hours, only the tubes are hot....
as predicted, the total power consumption was around 220 watts...so that at 20 watts music output, overall efficiency is a mere 10%...
Old 29th October 2012, 10:59 PM   #47
TonyTecson's Avatar
My Russian SET
tube compliments: 6C33 output tubes, 6P15P voltage amplifier/driver, 6N1P buffer, CG13 150v gas regulator tube......as you can see these are all Russian tubes....
Old 30th October 2012, 07:31 AM   #48
ma_coule is offline ma_coule  Slovenia
My Russian SET
Hi Tony,
do you have any concerns about that?
Otherwise... my congrats! Great build!
Old 30th October 2012, 09:44 AM   #49
TonyTecson's Avatar
My Russian SET
Originally Posted by ma_coule View Post
Hi Tony,
none, i have grown to respect Russian tubes ever since i made my first 6H23 preamp....over a year ago.....
and after over 30plus years haitus, i ma making tube amps again, i am retired now and i know that i have to keep challenging my mind....an this is my way of doing it...
Old 10th August 2014, 03:58 PM   #50
huseying is offline huseying  Turkey
Send a message via MSN to huseying
AJT thanks a lot to let us to see your amazing work.
It looks 100% DIY project, congratulations
Also i did a couple of tube project but coudnt find a chance to deal with 6c33 but i am planing to do.
If posibble can you compare 6c33 SE amp's sound to the 300b because i have listened a couple of times 300b
My ebay tube store
http://www.ebay.com/usr/hgungor10
My Russian SETHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 11:46 AM
NOS Capacitors(russian, phillips), Russian tubes, SS amp kits, power TX rvrazvan Vendor's Bazaar 0 26th May 2011 04:32 PM
WTT: One set of F4 boards for one set of F3 boards KT Swap Meet 0 16th May 2008 03:49 PM
Iron set for Paraglow (2A3) SET amplifier Alain Favret Swap Meet 1 19th March 2004 06:23 AM
Copyright ©1999-2017 diyAudio
