Which pins to use first? - diyAudio
Old 15th July 2012, 12:07 AM   #1
Default Which pins to use first?
I'm no designer so I don't know why this is. I've noticed that when a twin triode such as a 12AX7 is used in the front-end of an amp, the higher number
pins are used first (6-7-8) and the others (1-2-3) next. This practice is not restricted to the 12AX7. I see this with many twin triode. It also does not matter how the tube is used. Is there a reason for using the second section of the tube first? Does it Matter?
Old 15th July 2012, 01:13 AM   #2
ArtG is offline ArtG  United States
Perhaps it has something to do with how the tube is viewed. A tube designer would probably visualize the tube looking up from the base into the tube. A designer of sockets, or circuits would probably see things from the opposite direction. On "twin" tubes the characteristics are supposed to be identical, although I notice that in certain tubes, the interelectrode capacitance sometimes varies from one section to another.
Old 15th July 2012, 05:51 AM   #3
AJT is offline AJT  Philippines
AJT's Avatar
no two tubes are exactly alike, even if they are inside the same envelope....so that i use these sections as i see fit.....to my liking....
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 15th July 2012, 06:17 AM   #4
tomchr is offline tomchr  Canada
tomchr's Avatar
I just use whatever works for the layout.
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 15th July 2012, 07:08 AM   #5
maxro is offline maxro  Canada
maxro's Avatar
Some otherwise "twin" triodes, like the 6DJ8, have different heater-cathode voltage limits on the two triodes. These need to be wired in a certain order when used as both halves of a DC coupled stage, i.e. common cathode to concertina phase splitter.
"No one likes jazz that much; even the guy playing it had to take drugs." -Bart Simpson
Old 15th July 2012, 08:45 PM   #6
DF96 is offline DF96  England
If an AC heater is used then hum may be better for one section. Read the datasheet - always a good idea!
Old 16th July 2012, 08:10 AM   #7
Dragondreams's Avatar
I find it just makes the layout a little easier (in guitar amps).
Experience is what teaches us to make a different mistake next time...
z-5300 sub pins superxpro12 Subwoofers 4 20th April 2015 06:33 PM
Connector, where can I get pins for it? AdamB Parts 6 14th March 2006 04:13 PM
Why that many DECOU pins? roibm Digital Source 14 6th December 2005 10:54 PM
why multi pins ? 6SN7GT Tubes / Valves 9 10th July 2004 02:46 PM
crystal with three pins.. Marlowe Digital Source 4 16th January 2004 04:50 PM
Copyright 1999-2017 diyAudio
