Newbie needs help
Newbie needs help
Old 14th July 2012, 08:54 AM   #1
madman366 is offline madman366
Default Newbie needs help
Hey guys I just have one quick question about my yaqin ms 20l amp and how i have it set up. Right now i am using a pure I20 dock running to a dacmagic and then to amp. I also have my turntable running to a cambridge audio phono preamp. My question is the dac has a output of 4 volts and i believe the phono amp is 5 volts,yesterday while searching around on how to improve the sound i found out my amp should have a input of .25volts. Is .25 volts the min i need or do i have to drop the signal voltage some how? If i do have to drop signal i have no clue on how to do it. Also i have been running it this way for 2 months could i have damaged anything? Thanks Dennis
Old 14th July 2012, 09:56 AM   #2
DF96 is offline DF96  England
0.25V is the signal needed to provide full output. You have more than that, so the issue then becomes whether you have too much. That depends on exactly how the Yaqin does its volume control. However, if it sounds OK with no obvious limiting or distortion on music peaks then it is OK.
Newbie needs helpHide this!Advertise here!
[NEWBIE]Amplifier Design[NEWBIE] KernelPanic Solid State 13 7th December 2011 02:32 AM
Newbie w/ sub ?'s toenail Multi-Way 2 8th March 2003 01:10 PM
Newbie needs serious sub help AcidRain Multi-Way 4 7th March 2003 07:07 PM
help a newbie! fezz Solid State 5 22nd October 2002 09:19 AM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Copyright ©1999-2017 diyAudio
