diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Marantz Model 9 (http://www.diyaudio.com/forums/tubes-valves/216118-marantz-model-9-a.html)
mr2racer 14th July 2012 12:53 AM
Marantz Model 9
Hello everyone,
I've been toying with the idea of building a pair of Model 9 monoblocks. And the output transformers seem to be a real stumbling block. From my research I've found for 8 ohms out they see a 3000 ohm PP. And if I'm not mistaken I think I remember seeing a 22% ultralinear screen tap. Obviously forget about the tertiary feedback windings. But has anyone seen such a transformer readily available?
I looked at Luhndal, Hammond, and Edcor. I was intending to use Plitrons but was warned against torroidal outputs. I have yet to talk to Heyboer, they seem to close right after lunch!
I think these may need to be custom? Any help would be appreciated.
kevinkr 14th July 2012 01:18 AM
Jack Elliano over at Electra-Print is another one to talk to, his OPTs are quite good. (I use a pair of customs he built for my GM 70 SE amps)
He is also reasonably priced.
mr2racer 14th July 2012 02:05 AM
Thanks Kevin. I completely forgot about Electra-print. I also forgot that I once asked Heyboer about Dynaco A451's which might work. 2200ohms but maybe a little massive. Heyboer quoted me $235 each which seems very reasonable. I'll contact Jack right away.
kevinkr 14th July 2012 03:07 PM
I suspect Jack can wind you something that is a bit closer in spirit than the dynaco A451.. :)
tkk810 19th July 2012 12:33 PM
[QUOTE=mr2racer;3091478]Hello everyone,
I'm using Tamura F-2010 SERIES
(Bilirite Series)
mr2racer 22nd July 2012 06:28 PM
TKK810
Ever seen a price for the F-2011?
tkk810 23rd July 2012 04:59 AM
i brought the pair at $2300 (Est USD$2000) about 10yrs ago
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
