best schematics for single ended & push-pull - Page 2 - diyAudio
Old 8th March 2002, 07:17 PM   #11
p31r:
A friend of mine (Bob Danielak) made an amp using the "Sakuma principle" of transformer coupling and using the same tube for driver and final output.
He called it the "Sakuma Darling" and it used a step-up transformer at the input (4:1) into a 1626, interstage transformer coupled to a 1626.
We listened to several different 1626 amps together and in some ways this was my favorite, this approach clearly has a lot of merit.
-j
Old 9th March 2002, 10:41 PM   #12
dice45 is offline dice45  Germany
Jeremy,
then you definetely should try it our yourself , using the #46 tetrode, or how RCA preferred to call them, "dual grid tube". The tube is meant for that!
Sakuma style #46, this would be a killer!
Bernhard
Single-ended OR push-pull? kacernator Tubes / Valves 48 31st March 2008 02:50 PM
Single ended amp from class A push-pull Wavebourn Tubes / Valves 2 12th October 2007 09:14 PM
Is single ended Class A better than push-pull? okhifi Tubes / Valves 49 1st September 2005 07:26 PM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 06:04 AM
Copyright 1999-2017 diyAudio
