First attempt at tube amp. - diyAudio
Old 13th July 2012, 01:11 PM   #1
Default First attempt at tube amp.
Afternoon all, well as stated in my intro thread I want to try to build a Valve Guitar Amp. I have been looking around on the net and have decided that I would either like to base my amp on the VOX AC30 or the Peavey Classic 30. I have seen pleanty of versions of the electrical schematics for both amps, which it has to be said look very complicated. I have started trying to get a base idea of what valves I will need to be using. After looking at these schematics I will be using a GZ34 Rectivier, a bunch of 12AX7's and a bunch of EL84's.
My first question would be how do I work out what input transformer I should be using, I have seen a schematic for the AC30 saying that it should be a 300-0-300, 5 and 6.3 and I have seen aonther one saying a 180-0-180,5 and 6.3. What determines the voltages that I need? Being that these input trafos are hard to find, I want to try to get it right first time.
Thanks for your responses in advance.
G.
Old 13th July 2012, 01:39 PM   #2
DF96 is offline DF96  England
There is a separate forum for instruments and amps. You may get better answers there.
What you call the input transformer is actually the mains (UK) or power (US) transformer. An input transformer is something rather different.
Old 13th July 2012, 11:21 PM   #3
jerluwoo's Avatar
The difference in the transformer voltage is likely that the 300 0 300 uses a tube rectifier and the the 180 0 180 uses solid state to achieve approx. the same voltage output.
Old 13th July 2012, 11:25 PM   #4
mr2racer's Avatar
This might be a place to look?
Kits - Guitar Tube Amp
My first amp attempt... SMOTH Solid State 3 4th February 2012 06:52 PM
RE: My first attempt at using Tube Cadd deafbykhorns Tubes / Valves 2 4th October 2011 07:44 AM
Any good tube amp kits for a first attempt? Boscoe Tubes / Valves 26 22nd December 2010 12:13 AM
Hipass filter to control master bias? - Why attempt to reproduce DC in a tube amp? speakerfritz Tubes / Valves 13 12th December 2010 02:23 PM
Attempt at an amp with a few watts akis Solid State 2 2nd October 2009 07:03 PM
Copyright 1999-2017 diyAudio
