diyAudio Sponsor
Old 16th October 2003, 06:09 PM   #1
G is offline G  United States
G's Avatar
Default Comments on this design?
I'm building a SE EL34 amp that I designed and I managed to get a pair of Magnequest TFA 204 transformers for it. I have a small problem in that the transformers will only handle about 60mA of current through the primary before they start saturating so I will have to bias the EL34s at about 55mA or so to use them. I went looking around the net to see if I could find a design that ran them at that low of a current and came across this:
http://www.angela.com/catalog/how-to/EL34.gif
You'll notice that he is using a 880 ohm resistor on the cathodes of the EL34s and is showing 28 volts on the cathode which would of course mean that he is running a bias of about 32mA. This seems really low to me. Has anyone built this design or have experience with running EL34s at a lower than optimum bias? Thanks.
G
Gavin
Any comments on this design? icebear Tubes / Valves 23 19th May 2009 05:07 PM
Need comments on amp design mightydub Solid State 28 24th December 2008 02:01 AM
My first amp design - comments blueskynis Solid State 36 26th March 2008 04:38 PM
need comments on amp design metebalci Tubes / Valves 0 10th September 2006 09:03 PM
comments on this design.. GeirW Tubes / Valves 6 13th February 2004 09:24 AM
Page generated in 0.06360 seconds (65.54% PHP - 34.46% MySQL) with 10 queries
