Will this ebay cover fit my Scott 272 integrated amp?
Old 10th July 2012, 02:42 AM   #1
bigbargain is offline bigbargain  United States
bigbargain's Avatar
Default Will this ebay cover fit my Scott 272 integrated amp?
Sorry the ad doesn't contain alot of info but I have asked him for more. I will post whatever he answers.
However while I wait, I was hoping someone here knew more about Scott 272 covers than I do (I've never seen one, but I do have the amp).
THANKS for any help you can provide!! (of course I need an answer quick as the auction is going to end soon)
VINTAGE SCOTT TOP COVER FOR SCOTT INTEGRATED TUBE AMPLIFIER | eBay
Old 10th July 2012, 12:04 PM   #2
bigbargain's Avatar
Default Got an answer...
He says the cover fits a 222 or a 299. So what does that say about my 272? Does this clue help answer the question of if it would fit?
Old 10th July 2012, 04:54 PM   #3
kevinkr's Avatar
Try here for some additional information: HHScott Vacuum Tubes -- Collectors' Corner, Technical Restoration Advice
It appears that the associated forum is dead and gone, the last updates here were around 2004, but there is a lot of information available there.
I used to service a lot of vintage Scott gear in the 1980s and 1990s, but no longer remember a whole lot of detail. I suspect the 272 will not fit a case for a 299..
In addition when installed in a case these amplifiers run extremely hot and it is probably kinder to the amplifier not to run it in a case at all, and they do look cool.
Hopefully yours has been thoroughly gone through, and critical coupling caps and supply electrolytics replaced.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th July 2012, 06:04 PM   #4
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
I don't have a 299 handy, but my memory says that they were smaller than the 272 which is pretty big.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 10th July 2012, 06:12 PM   #5
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
The 272 was taller than the 299. Not quite as wide.
Frank
Old 10th July 2012, 07:04 PM   #6
Triodethom is offline Triodethom  United States
Triodethom's Avatar
The 272 beside me is 15.25 in wide 13.625 deep and 5.5 in tall.
Old 10th July 2012, 07:12 PM   #7
My HH Scott 299-C is 14.5" wide, 12" deep and 4" tall.
These are the chassis dimensions.
Frank
Old 10th July 2012, 11:07 PM   #8
bigbargain's Avatar
Default You guys are Awesome!
I knew this was the right place to ask my question.
Guess it means I won't be buying that cover, but given the comments maybe it was a good idea not to (heat).
I do want to put a cover over it - originally I was thinking about reusing the walnut that the big record storage, etc. cab that it came in. Beautiful wood, but I only want something to make the actual amp look "finnished".
So how big a problem will heat be if I put it in a case, and is there any suggestions for reducing heat (I don't want a fan in it). I see lots of cases with big screened areas over the tubes. That's the design I was planing to use, but are you saying that even that will reduce air flow too much?
Will this ebay cover fit my Scott 272 integrated amp?Hide this!Advertise here!
Scored a very nice H H Scott 272! bigbargain Tubes / Valves 42 10th September 2013 11:24 PM
Anyone own an HH Scott LK-72 Integrated amp? Captn Dave Tubes / Valves 6 4th October 2010 04:56 PM
Alpair-10: to cover or not to cover, that is the question markaudio Full Range 13 1st March 2010 08:07 PM
Ebay: DIY 6L6GC PP integrated amp dmitriy167 Swap Meet 0 18th March 2007 12:04 AM
Nad 272 power amp barfind Solid State 2 4th September 2005 05:37 AM
