Thordarson Dual Tone Control
Old 9th July 2012, 08:27 PM   #1
xpl1c1t is offline xpl1c1t  United States
Default Thordarson Dual Tone Control
I stumbled upon this tone control schema in an old Thordenson catalog.
It appears to alter the treble at the grid and bass at the plate, uniquely using a 22H ~2kohm choke for the bass.
Relevance;
I'm currently designing a EF86 preamp that feeds an interstage transformer for phase splitting into a push pull output stage. For this design, I want to use a cathode follower to maximise the voltage step-down i need from the interstage transformer - therefor I'd like to use a cathode follower.
Now, i'm in the dark regarding the use of this design with a cathode follower stage. Is it advisable to strap this tone control to the EF86, or should it be separated from the pre for the same reasons so many people use cathode followers, and in that case how would it be used? Any advice would be great.
Cheers!
PDF Description and schematic here:
http://www.google.com/url?sa=t&rct=j...hMoyBAtRPiu13A
Old 10th July 2012, 08:11 AM   #2
Well lookie here, found an old Gibson circuit schematic which implements the control on its preamp stage.
http://www.el34world.com/charts/Sche...son/EH-195.pdf
Thordarson Dual Tone ControlHide this!Advertise here!
Tone control argonrepublic Solid State 11 13th November 2011 01:32 AM
To tone control or not to... dagerman Tubes / Valves 12 27th June 2011 06:15 AM
DIY Dual Channel Active Tube Tone Control HideawayStudio Tubes / Valves 1 1st November 2010 01:05 PM
Tone control argonrepublic Solid State 0 28th February 2010 12:12 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
