WE448A data
WE448A data
Old 9th July 2012, 07:44 AM   #1
Zeta4 is offline Zeta4  United Kingdom
Default WE448A data
Hi
Does anyone have data for triode connected WE448A? I have some
which I would like to try in a couple of applications. Curves etc would
be ideal but basic data like mu would be a help.
Old 9th July 2012, 08:15 AM   #2
guss013 is offline guss013  New Zealand
You could try here...
Western Electric
hope it helps :-)
Old 9th July 2012, 04:21 PM   #3
Thanks, I have that data but its for the tetrode connection.
I did see one mention of a mu of 4.9 and an Ra of 4K
but surely the mu figure cant be right. Maybe its 49
which is much more likely.
Ah well Ill just have to experiment a bit.
Old 9th July 2012, 04:33 PM   #4
kevinkr's Avatar
WE448A data
I believe the data sheet here: http://www.westernelectric.com/spec_sheets/448B.pdf See figure 1 which appears to be curves with the plate and screen grid tied together. (Triode connection)
Make a simple test jig and do some measurements. If you use a good CCS load and tie plate and screen grid together with fixed grid bias you can measure mu directly.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th July 2012, 05:17 PM   #5
Thanks kevinkr, I hadnt noticed the apparent triode connection
in fig 1.
I guess I will have to measure it as you suggest.
Old 9th July 2012, 08:38 PM   #6
7N7 is offline 7N7  United Kingdom
7N7's Avatar
I don't think that is correct; I believe that they mean that both Anode and G2 are at 150V which of course is not quite the same as triode connection.
The valve appears to be very similar to the Swedish (Ericsson) A-1600 a.k.a. 7150 . I had some of these once, stubby bulb, Magnoval B9G base, Va (max) 150V etc. the data are in the Vade-Mecum section 108. I did make some curves but these are now lost I'm afraid. Mu was about 30 as I recall.
Paul
Plug them in and light them up
Old 10th July 2012, 01:23 AM   #7
kevinkr's Avatar
WE448A data
<snip>
Paul
The curves do look triode like. The statement Eb=Ec2=X volts is a somewhat common nomenclature for triode connection here, (both WE and Sylvania were known to publish data sheets this way) and I interpreted the individual curves as being the combination of Eb=Ec2 at the plate voltage given to the right of the curve.
The curves certainly don't look that great, but may in fact be better than shown when actually measured. These might be good in something like a phono stage if the mu turns out to be reasonable.
Old 10th July 2012, 09:05 AM   #8
7N7's Avatar
No they are not triode curves; these curves - transfer characteristics with Va constant and varying G2 voltage and G1 voltage - appear regularly in pentode and beam tetrode data sheets. For example have a look at the nice set for the pentode section of 6AW8A here.
Paul
WE448A dataHide this!Advertise here!
original transistor data bank-useful data federico moreno Solid State 17 9th April 2011 04:19 AM
30MB6 data rsumperl Tubes / Valves 4 19th April 2010 07:13 PM
Data from my FIRST DIY TurboFC3S Multi-Way 10 17th December 2006 04:28 AM
OT data trancy Tubes / Valves 11 8th July 2005 03:58 PM
Hello from Ukram Data ukram Introductions 2 20th June 2003 07:40 AM
Copyright ©1999-2017 diyAudio
