Any body can help to identify this pair of OPTs. - diyAudio
Old 9th July 2012, 01:18 AM   #1
Default Any body can help to identify this pair of OPTs.
I've got a pair of ADC pre-amp opts by chance. Model No. TF1A13EB, frequency response 250-20KC, and impedence ratio 100K : 600Ohms. I can't find the detailed specifications for these transformers. Anybody can give me a hint? Many thanks.
Old 9th July 2012, 08:23 AM   #2
hidnplayr's Avatar
Looks like they came out of some army equipment.
Product / Part Number: A8046 - TRANSFORMER,AUDIO F by ADC TELECOMMUNICATIONS INC. - 00144 - ArmyProperty.com
Real tubes have top-caps
Old 9th July 2012, 08:34 AM   #3
TonyTecson's Avatar
everything's been given, what more do you need? you can measure dc resistance of windings if that will be of use to you...not a hifi traffo it seems...but at low levels who knows? use it in a circuit to find out...maybe as a headphone opt.....a headphone of 32ohms reflects about 5k in the primary....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 9th July 2012, 09:06 AM   #4
trobbins's Avatar
ADC made commercial/military grade transformers - I've got some coupling transformers that are speced as +/- 0.1dB across the telephony range, and happily go flat beyond my audio measurement range. Yours may be excellent, and have a DC mA rating as well, so may work well as a SE valve driven line driver.
Old 9th July 2012, 09:59 AM   #5
Bone is offline Bone  United Kingdom
look like they may be sonar transducer matching transformers??
FS: pair James 6123H OPTs, Champagne color jmillerdoc Swap Meet 2 2nd November 2011 06:32 AM
have a pair of 5k:8 OPTs lying around.. suggest me something to build? d3aPentode Tubes / Valves 22 31st August 2010 09:54 PM
FS: Pair Edcor 6k6 60W OPTs 4/8/16 secondary... $130 jon_010101 Swap Meet 5 5th March 2009 04:18 PM
FS: Pair semi custom Magnequest RH40 SE OPTs jrebman Swap Meet 3 2nd August 2008 01:03 PM
Lprimary variation in pair old opts Klimon Tubes / Valves 9 7th May 2007 12:54 AM
Copyright 1999-2017 diyAudio
