Pre-amp for Tube Sound
Old 12th July 2012, 02:32 PM   #11
Loren42 is offline Loren42  United States
Originally Posted by Evenharmonics View Post
No, it's the opposite. What the listeners commonly characterize as "tube" sound is the dominance of second order harmonics followed by much weaker third order harmonics and then diminishing harmonics beyond those. It's the typical traits of SE design.
The other "tube" sound that listeners describe is the high frequency roll-off of some tube amps. You can make class AB transistor amp to sound like this by using equalizer.
I understand now. I was considering a push-pull amp and those distortion components should be inaudible if the amp is working correctly.
SE amps produce much more distortion which is audible, which I guess is the "tube sound".
Old 12th July 2012, 02:44 PM   #12
disco is offline disco  Netherlands
disco's Avatar
No, you're wrong. Second harmonics up to 1% are not noticeable by ear. Half that value in 5H or 7H is, that's why most listeners to quality gear appreciate good tube amps over good SS amps.
jaap
Old 12th July 2012, 02:51 PM   #13
disco's Avatar
Sorry, there's no tube sound. Tubes only produce sound under bad conditions like dropping on the floor, disconnecting a loudspeaker or using outside their optimal operation area (for effects or musical instrument amplifiers). To some this statement is outside their comfort zone it seems
jaap
Old 12th July 2012, 02:57 PM   #14
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
I agree with you based on my experiences and Pete Millett's article
as follows:
the Sound of Distortion
I like the sonic of my 211SET.
Old 12th July 2012, 04:17 PM   #15
Evenharmonics is offline Evenharmonics  United States
How did you find that out?
Strong even harmonic (second order) masks odd harmonics that follow which is the typical traits of SE amp. That's what people notice when listening to SE amp and PP amp at equal volume.
Here are the measurements of 3 different amps at same output under 8 Ohm load. 2 are PP design and 1 is SE. Second harmonic from SE amp is about twice as high as third harmonic that follows. The other 2 amps don't have the benefit of even harmonic masking.
Old 12th July 2012, 04:23 PM   #16
I'm not sure how the two contrasting posts can be made by one person.
Old 12th July 2012, 04:27 PM   #17
Bigun is offline Bigun  Canada
Bigun's Avatar
I've engineered 2nd harmonics into solid state amps before - they didn't sound like tube amplifiers though and only one of them sounded nice, when not pushed too hard. I have a single ended tube amp to compare them with.
I suspect that if you want tube sound, you need a tube amp. Putting a pre-amp in place for tube sound might work if the SS amp is so clean it just gets out of the way, but tube amps are also about how they interact with the reactive load of a speaker.
I came to the conclusion that putting a tube in front of a SS amp hoping for that old tube sound is like putting a Weber carb on a Ferrari engine hoping it would drive and sound like a 1964 Mustang.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 13th July 2012, 07:31 AM   #18
disco's Avatar
Have a test to distinguish a 1% 2KHz sinus (that's -40dB) from a 1KHz sinus. Hold that level and turn up the frequency. What's your conclusion?
There's simply more to a tube amplifier than THD only, that's my point.
Please don't play word games, you're better than that. I won't place my words on a scale before posting, it's robbing the fun from a forum.
jaap
Old 13th July 2012, 03:17 PM   #19
You quoted my post pointing out your contradiction of your own post and your reply is about playing sine wave?
"there's no tube sound."
"that's why most listeners to quality gear appreciate good tube amps over good SS amps"
Did those listeners listen to music instead?
I don't remember saying there isn't. Anyway, can you name some of them?
I've already explained to you on the importance of wording on internet forums (link) and yet those words seem to have hit the brick wall!
To you, it's ok to post misleading info online as long as you are having your own fun?
Old 13th July 2012, 03:32 PM   #20
I think you nailed it. It is all about driving the reactive load and the difference between a current drive amplifier (tube) and a voltage drive amplifier (solid state).
A tube preamp driving a solid state amp will not inject magic into the system. Any sound difference noticed will have to do with the quality differences between the two preamps.
I think the analogy you actually meant was putting Weber carburetors on a 1964 Mustang and thinking it will perform like a Ferrari 308.
Pre-amp for Tube SoundHide this!Advertise here!
Tube Pre dull into Tube Amp - cause ? billzoe Tubes / Valves 4 14th May 2012 08:13 PM
not balance sound on tube pre-amp tony Ma Analog Line Level 6 15th December 2011 03:49 AM
tube pre and tube power amp tiguan Tubes / Valves 7 28th January 2011 05:42 AM
SMPS & tube pre-amp development board. ianl Tubes / Valves 2 10th April 2006 06:05 PM
the unstable sound from tube pre-amp ! up4 Tubes / Valves 14 23rd October 2002 12:19 AM
