diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Audion tube amp capacitor questions (http://www.diyaudio.com/forums/tubes-valves/215767-audion-tube-amp-capacitor-questions.html)
Coconuts 500 7th July 2012 11:33 AM
Hi
I want to replace the capacitors in this tube amp. (Schematic here). Specifically the caps that are installed right after the rectifier. I am wondering if the Panasonic EE series would be suitable for the application. I've read that you need high ripple caps in this location, and these do look suitable to me:
Datasheet Panasonic EE radial
I am thinking about replacing the four caps (100uF/100uF/75uF/25uF) with four 47uF/450V caps instead, since other values have been hard to find. Is this a good idea?
Any help greatly appreciated. :)
DF96 7th July 2012 01:01 PM
Unless you can understand and recalculate the effects of a change, stay with the values of the original circuit (plus or minus 20%). You can always parallel two 47uF caps to replace a 100uF cap.
Coconuts 500 7th July 2012 07:36 PM
What about the series itself? Will it be suitable? There are other values.
astouffer 7th July 2012 07:45 PM
Looks good to me, 105c ratings are a must for tube amps.
Copyright 1999-2017 diyAudio
