#2 |
FWIW, from an online review:
"The ES80 presents a nominal 8 ohm load with a 91dB efficiency. The speaker proved to be a tougher load than the specs would indicate and needed good-quality power to open up properly, not excelling with entry-level power sources. Better-quality power sources improved things significantly." That does not bode well for use with low power tube amps, especially those amps with no global NFB to reduce the amp's output resistance. -- |
#3 |
Bruce, there are many good choices out there. What's your budget?
#4 |
I'd consider other options. How much $$ do you have to spend?
#5 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
Depends on the tube amp of course, some it will suit, some it won't. Some tube amps due output impedance don't suit multiways at all. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 |
I'm pretty happy with my KRK R6 speakers on my 300B SET amp. I paid $240 total including shipping for the speakers.
Studio monitors is where it's at in my opinion. Incredible bang for the buck. And specs... What a concept. My KRKs are flat from about 50~60 Hz up past 15 kHz. I think at 20 kHz they're a few (2~3) dB down. Like most speaker with a passive XO, they do have a slight harshness around the crossover frequency due to cone breakup. I run mine biamped with an active XO. That takes care of the harshness... ~Tom
21st Century Maida Regulator, Universal Filament Regulator, 300B Driver PCBs, and more... Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right |
| Multi-way speaker for tube amps: what does really matter? | the Interceptor | Multi-Way | 3 | 3rd May 2010 09:56 PM |
| good book for learning the basics of tubes and tube amps | frajavcar | Tubes / Valves | 5 | 18th July 2008 07:33 PM |
| What speakers are good for tube amps?? | Rob.capone | Multi-Way | 19 | 31st August 2007 12:32 AM |
| Reusing old speaker cabinets. Good or bad choice? | maurycy | Multi-Way | 2 | 4th January 2006 11:38 PM |
| What’s a good choice of speaker | Hayden | Multi-Way | 20 | 15th October 2005 04:55 PM |
