Old 3rd July 2012, 10:02 PM   #1
Default Removing cathode-bypass capacitors, and compensation
What considerations are there when removing bypass caps from preamp stages?
I've removed a 22uf cap from a section of a 12ax7, and simultaneously changed the 220k plate resistor to a 100k (with 1.5k cathode resistor). I've seen that the output impedance goes up, and I've adjusted the value of the (de)coupling capacitor to keep the desired frequency response going into the next stage. But I'm wondering what other effects of "loading" should be considered.
I'm partially writing this post because, though I can find tons of posts on removing/not removing the cathode bypass caps for tonal modifications, I've yet to run into any information on the importance (or lack of importance) of adjusting for the change in output impedance.
any thoughts?
Bypass Cap on cathode? infernal Tubes / Valves 4 17th June 2011 11:40 PM
Polyprops as cathode bypass s2kov Tubes / Valves 10 3rd December 2004 08:56 PM
Cathode bypass caps? SHiFTY Tubes / Valves 18 21st August 2002 07:27 PM
Cathode bypass cap ? woody Tubes / Valves 2 19th May 2002 05:53 AM
Best Cathode Bypass Cap Mohan Varkey Parts 4 6th May 2002 08:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
