diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   help with amp ohms (http://www.diyaudio.com/forums/tubes-valves/215540-help-amp-ohms.html)
madman366 3rd July 2012 08:13 AM
help with amp ohms
hey guys
i am new to forum i just have a quick question about what will happen to load on my amp which is a yaqin ms20l. i currently have a pair of altec m19s hooked up to it but wanted a little more lows so i ordered a bic f1 sub which should be here thurs. it has speaker level inputs and shows that you run wire from amp to sub and then there is a speaker out that goes to main speaker. i dont want to go that way i want my m19s to get all the signal so i am thinking about just running wire to my speaker and then to sub which has its own amp will this drop ohms load on the yaqin from 8 down to 4? any info would help thanks dennis
Vinylsavor 3rd July 2012 08:33 AM
Hi!
If this is an active sub it most likely has a high impedance input which will not affect the loading of your amp. But check teh datasheet of your sub to verify
Thomas
tricomp 3rd July 2012 08:34 AM
1 Attachment(s)
Hi madman366,
Take a look at the back of your amp. or have a look at the attached photo of your amp's rear.
Doesn't seem to be a problem with 4-Ohm.
I would be more concerned with your keyboard that seems to have dropped CAPITAL letters.... :D
rgds,
/tri-comp
Resources saved on this page: MySQL 18.75%
