| diyAudio Sponsor | ||
#21 | |
#22 |
Which would have more power, a SE 807 or a SE EL34?
Joe |
#23 |
According to TDSL in SE mode as a pentode:
11.5 watts for an 807 with 500 V supply and a 6K transformer 11 watts for a EL34 with 250V supply and a 2K transformer According to TDSL in SE mode as a triode: 807 not listed in this mode of operation. 6 watts for a EL34 with 375V supply and a 3K transformer. |
#24 |
My first encounter with the 807 amplifier I purchased left me with a sick feeling in my stomach which resulted in my sending the amplifier back to the manufacturer for repair.
I just received the amplifier back the other day. My first impressions were good until I started to push the little devil. What had started out to be somewhat sweet sounding turned like a spoiled stepchild. Distortion and a crackling noise resulted from within. At this point in time I was prompted to do a power test to see what I could find out. The results didn't quite live up to the telephone conversation I had with the engineer/builder. I was promised over the phone that the amp was going to deliver 9-10 watts output. I actually got around .7 watt into an 8ohm load. Having remembered that someone had mentioned that I sue for false advertising I drafted a rather heated email to that effect. I received a reply to pack it up and notify them and they would send a call tag for it. I think that with the guidance and help here I can build something much better. Burnedfingers |
#25 |
#26 |
After letting this amplifier go years ago I have always wondered if I could build a SE amplifier like this one that would be capable of not only more power but maybe a little sweeter sounding. I would like to use a 6SL7 and 6Sn7 and 807 as my tube line up.
Anyone have any ideas?
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.09985 seconds (71.96% PHP - 28.04% MySQL) with 11 queries |
