12 VAC for both AC heaters and DC B+ via voltage doubler? - diyAudio
Old 25th June 2012, 05:36 PM   #1
MarkER is offline MarkER  United States
Default 12 VAC for both AC heaters and DC B+ via voltage doubler?
I've built small guitar amp using space charge tubes:
Sopht amps - all tube 30v amps
I was using parts on hand and have a 12 VAC/3500 mA wall wart. It works great on the heaters that use plenty of current, but was wondering if I could also run a voltage doubler to give the 24VDC for the B+. I realize that it will generate more than 24VDC, but would bring it down with a suitable dropping resistor. Currently using 3 9V batteries in series for the B+.
Thanks in advance.
Old 26th June 2012, 08:04 AM   #2
Austin Translation's Avatar
Send a message via MSN to Austin Translation Send a message via Skype™ to Austin Translation
I wouldn't worry about the dropping resistor, it's going to sag. A voltage doubler puts off a pretty chopped up form of dc and rc filtering will fix it but it's going to sag some with any load at all on it.
Tube heaters AC or DC? soundbadger Tubes / Valves 183 21st December 2016 10:19 PM
Heaters & Filaments: AC vs. DC nazaroo Tubes / Valves 155 3rd November 2014 08:30 PM
Need schematic for AC to DC converter (12V AC in to 12-18V DC out) maurycy Power Supplies 6 6th January 2012 08:27 PM
Changing AC heaters to DC bereanbill Tubes / Valves 5 15th May 2009 06:32 PM
AC or DC for 300b Heaters sgerus Tubes / Valves 73 22nd May 2007 12:48 PM
Copyright 1999-2017 diyAudio
