Old 25th June 2012, 03:35 PM   #1
Default BCF build
I bought a BCF kit and I'am in the process of trying to determine resistor values.
John "threw in" 2 Russian 6H6N tubes but none of the charts included in the manual include this tube. Can anyone help?? transformer is 240 240 6.3 6.3 with a 240ct
Old 25th June 2012, 03:45 PM   #2
This isn't BCF specific, but I found this datasheet:
6N6P, 6N6PI (6H6n, 6H6nN)
apparently the N or P is interchangeable, along with others.
Max 300v anode, 6.3v heaters. Your tranny should be able to swing it. It does draw nearly an amp of heater current though - so that load is something to watch for. 1 meg grid/input resistor.
Build or not to build - $300-500 budget sasav Multi-Way 19 6th January 2012 02:27 PM
What should i build? Rullknufs Headphone Systems 13 16th March 2011 04:27 PM
What to build with these... Mayday Full Range 46 23rd April 2007 09:07 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
