diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Settings for ECC808 tube on 539c tester (http://www.diyaudio.com/forums/tubes-valves/215001-settings-ecc808-tube-539c-tester.html)
MateKrisz 23rd June 2012 03:26 PM
I have some NOS Tungsram ECC808. I can't test on my Hickok 539C tube tester, because I not found correct settings. What is the good settings for this tube?
HollowState 23rd June 2012 04:39 PM
I have the latest test data book for the 539C, but an ECC808 is not listed. However, a 6KX8 is listed and is very similar. So I would test it as a 6KX8 and go from there.
6KX8
6.3V EV-9708-6 1.3 .... P4 E 800 triode 1
6.3V EV-1302-6 1.3 .... P4 E 800 triode 2
rongon 23rd June 2012 09:06 PM
According to this here ECC808 is pretty much the same as the good old 12AX7 (ECC83) but with a different pin-out. I hope that helps.
ECC808 datasheet
MateKrisz 25th June 2012 08:10 AM
Working! :) Thanks for your help! :)
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
