RIAA Tube Preamp Build (Part 1) - Page 2 - diyAudio
Old 25th June 2012, 11:44 AM   #11
DF96 is offline DF96  England
Where is the 'standard' RIAA circuit? Time constants 3180, 318, 75 us? Do none of your LPs use this equalisation? What you have called Basic RIAA is not RIAA but a rough approximation to the LF end of it.
Old 25th June 2012, 03:59 PM   #12
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Interesting idea of using selectable networks, but I wonder how much noise this will introduce into the circuit.
Old 25th June 2012, 04:12 PM   #13
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
In the book of Langford & Smith there is an entire chapter dedicated to multiple disk equalizer networks.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 25th June 2012, 05:22 PM   #14
tmblack is offline tmblack  United Kingdom
It is common to use negative feedback loops; see Audio Research SP3, SP6 almost all use similar design.
What is the noise level of a 6922 and how does it compare to a 12ax7a?
Help me to Build Tube Preamp with Phono tony Ma Analog Line Level 1 12th April 2011 06:45 AM
Tube preamp build help-heaters Barrington Tubes / Valves 15 20th June 2010 10:59 PM
My own RIAA tube preamp ronned2tm Tubes / Valves 7 11th December 2009 02:49 AM
tube preamp RIAA radiodieg Tubes / Valves 5 3rd September 2008 02:36 PM
Single Tube RIAA preamp too good to be true? alexmoose Tubes / Valves 16 22nd October 2007 09:09 PM
Copyright 1999-2017 diyAudio
