diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   DL22N (http://www.diyaudio.com/forums/tubes-valves/214862-dl22n.html)
stajo 21st June 2012 06:49 AM
DL22N
I have a bunch of those. They can come from some swedish military supply. I've read thar they were used in torpedo control systems:eek:
Anybody knows anything about them, if they can be used in audio, linearity etc? All I can find is this DL 22N, Tube DL22N; Röhre DL 22N ID33454, Vacuum Pentode and no datasheet.
Best regards
Staffan
jerluwoo 21st June 2012 10:56 AM
Some basic info here Electron Tubes & Valves Database - Index - Cross Reference under DL22. The DL22N has metal envelope instead of glass.
stajo 23rd June 2012 07:00 AM
Thanks. Well it seems like a low voltage direct heated pentode for battery driven amplification, so the torpedo rumour might be correct.
Eventually I could curve trace it manually. Anyone knows a thread about doing that?
Best regards
Staffan
hidnplayr 23rd June 2012 08:34 AM
DL22 is listed in the VADE-MECUM
http://frank.pocnet.net/short/054/1/197.pdf
Resources saved on this page: MySQL 18.75%
