Single Tube Amp - diyAudio
Old 21st June 2012, 06:01 AM   #1
Default Single Tube Amp
I have some leftover parts from a still born project of a couple years ago and was thinking of scavaging it for a new project.
I have an unused pair of EML 20B DHT tubes that I thought might be a good basis for a single tube amplifer.
Searching the web I found a couple of examples, but not a lot of detail.
Anyone here ever throw one together?
JD
Old 21st June 2012, 07:33 AM   #2
dsavitsk's Avatar
mu is really not high enough for use without a driver of some sort.
Old 21st June 2012, 07:40 AM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
not a lot of info, but just about enough to figure it out
Oleg's EML 20B SET Stereo Amp
that is, if its worth the trouble
those tubes wont last forever
or very short if less lucky
needed OPTs are far from optimal(high impedance)
still lots of expencive parts
my approach would be use as driver in a design where they could be easily replaced by a different driver tube, without major changes in the output stage
or simply build a seperate preamp/driver stage with them
Old 21st June 2012, 04:38 PM   #4
kevinkr's Avatar
As I recall the rp is fairly high making sourcing a good wideband OPT problematic.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st June 2012, 06:40 PM   #5
Comparable to a 211 as far as Rp is concerned, but even higher mu so the Miller capacitance will play a role.
When relieved from bass duties things would get better.
Other possibility would be a parafeed circuit, or if you hate capacitors: a 1:1 transformer followed by a "smallish" output (step-down) transformer
ECL82 Single Tube Amp Einric Tubes / Valves 40 6th June 2012 07:55 PM
Single ended KT88 tube amp BillFussIII Swap Meet 5 10th January 2012 08:11 PM
F* amp VS Single Ended DHT tube amp xecluded Pass Labs 15 11th August 2009 07:59 PM
Single Stage Line Amp (Diff Amp) Tube? AudioAngel Tubes / Valves 9 28th November 2006 11:38 AM
Copyright 1999-2017 diyAudio
