Question for EU diyaudio members
Old 24th June 2012, 09:17 PM   #31
DF96 is offline DF96  England
Old fogies like me still think in imperial, but calculate in SI.
Old 24th June 2012, 09:28 PM   #32
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Of course Metric measurements will have to be used; that's quite obvious, sadly it's the way things are.
I dislike the Metric system, partly because it reminds me of Bonaparte's arrogance, but principally because all the values are useless either too big or too small. The Imperial measurements are human in scale and conception and have the added advantage of fractions, apparently a closed book in the Metric world. I think that fractions are lovely things.
I should add that I am perfectly at home with Metric having been something of an Italian car specialist for more years than I care to mention.
Paul
Plug them in and light them up
Old 25th June 2012, 10:44 AM   #33
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
I will never understand how can someone, only with a quick look, realize how long is something like 3 1/23 inches or 5 1/7 inches. Why not just say 3,043" or 5,142"?
Best regards,
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 25th June 2012, 10:52 AM   #34
What's wrong with ~77.3mm & ~130.63mm?
regards Andrew T.
Old 25th June 2012, 11:05 AM   #35
monty78pig is offline monty78pig  England
monty78pig's Avatar
Metric is far more easier to use than imperial. Try adding 3 1/23 and 5 1/7 in your head and it should become pretty clear. Metric has the advantage of decimalisation perfect compatability between units, so no conversion whatsoever. Imperial measurements may be human in scale but they neglect the fact that our number system can only work in powers of 10.
http://www.objectivesounds.co.uk/ With perfect linearity, it is impossible to go off on a tangent.
Old 25th June 2012, 11:15 AM   #36
7N7's Avatar
I have never heard of anyone using such fractions as 1/23 or even 1/7 in measurement applications; the beauty is though they can be used if at all necessary.
I like the fact that base 12 can be divided by 2,3,4 and 6, and that the fractions used traditionally in measurements were all base 4 - 3/16, 1/4, 1/8, 9/64 and so on.
And defeating my own argument, was there ever a better unit for engineers than the "thou"? It's just the right sort of size, microns being quite ridiculously small.
Paul
Old 25th June 2012, 11:18 AM   #37
Easy: the answer is 8 and a bit.
If you work with computers you quickly learn to do arithmetic in octal or hexadecimal too. Some trades used to routinely work in dozens or gross. There is nothing special about 10 as a number base, except for those who still count using their fingers and toes.
Old 25th June 2012, 11:30 AM   #38
8 and a bit
ral (rolling about laughing).
That bit is 30/161, everyone is familiar with that fraction, it's ~0.188635........
3/16" is 0.1875"
8 3/16" is pretty close. 207.93mm is closer,
regards Andrew T.
Old 25th June 2012, 12:09 PM   #39
Perhaps we should remind younger viewers that fractions of an inch were usually based on powers of 2 (i.e. binary fractions) so adding was made easier. 1/16 + 5/32 = 7/32 - anyone over about 40 can do that in their head.
Old 25th June 2012, 12:11 PM   #40
But, 94% of the "under 40years" population can't do any arithmetic "in their head".
regards Andrew T.
Question for EU diyaudio membersHide this!Advertise here!
Question for EU members ValveKit Vendor's Bazaar 0 19th June 2012 03:40 PM
To all Indian diyaudio members jacobsetti Solid State 0 21st February 2012 01:07 PM
DIYAUDIO.COM Stickers For Members! jleaman Everything Else 13 15th June 2011 05:58 AM
How many diyaudio members are from Malaysia? Leolabs Everything Else 0 23rd July 2006 03:55 AM
Hello diyAudio members! Brian Guralnick Introductions 2 12th March 2002 07:04 AM
Copyright ©1999-2017 diyAudio
