I have a CounterPoint SA-12 that I just repaired but can not find the correct BIAS current setting for the outputs (orginal MOSFET). Can anyone help with this setting.
#2 | |
You may consider a lower quiescent current in the interest of preserving the ageing components in your amplifier. Alan
Alan Hope is not a reliable design discipline |
#3 |
That repair is long gone and the customer is very happy. I found the info you stated awhile back but thanks for the responce. I set the BIAS at 450ma and found no differnace in crossover distorshion. Thanks' again.
| Counterpoint SA-12 wackyness | TubeAmp222 | Tubes / Valves | 1 | 14th April 2011 03:06 AM |
| Counterpoint SA-12 outputs 2SK134/2SJ49 work?? | kilohertz | Tubes / Valves | 3 | 28th August 2009 05:17 AM |
| 2SK134/2SJ49 for output of Counterpoint SA-12?? | kilohertz | Solid State | 12 | 24th January 2009 02:44 AM |
| Counterpoint SA-12 | vsr123 | Solid State | 1 | 19th January 2009 01:13 AM |
| Counterpoint SA-12 | vsr123 | Tubes / Valves | 0 | 3rd July 2003 02:54 PM |
