Bleeder Resistor for Choke Input Supply - diyAudio
Old 18th June 2012, 03:59 PM   #1
Magz is offline Magz  United States
Default Bleeder Resistor for Choke Input Supply
Hello All,
I'm building an LCLC supply for a preamp, and wondering about the necessity of a bleeder resistor. The circuit has gas regulators drawing 45mA total in shunt from the HT to drop the voltage down to 225V, so once they strike, there is no need for a bleeder, as the minimum current for the 17H input choke is easily satisified. The voltage will climb higher before they strike, but all the circuit components are rated for far more voltage than the circuit can obtain in cap input.
The glow tubes act as their own indicators if there is a problem - no glow, then I know to shut down. Safe, right?
I'd rather not waste all that power and generate unnecessary heat if it's not necessary.
Old 18th June 2012, 04:20 PM   #2
Vinylsavor's Avatar
Hi!
The bleeder provides some safety. If the gas tubes don't ignite for any reason or tubes are not plugged in, the bleeder will ensure that the caps are discharged when you turn off. Some caps can hold their charge for days!
If sub critical current is drawn from the PSU, the output voltage will be up to 50% higher. Ensure your caps have a high enough voltage rating for that so nothing gets damaged just in case.
If you do not want to place bleeders which draw the critical current, at least install some with a higher resistance which will dissipate less power, but still ensure discharge of the caps in any case.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 18th June 2012, 05:15 PM   #3
Thanks Thomas,
Yes, I was planning to install high value bleeders to drain the caps, just not to draw the critical current. 200k should discharge the caps within 90 seconds without drawing very much current.
Old 18th June 2012, 05:59 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Be sure to no put any condenser directly in parallel to the VR, otherwise an RC relaxation oscillator you will do.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 18th June 2012, 06:34 PM   #5
Yes, I've already breadboarded and listened to the preamp portion of the circuit using a different, CLCLC power supply, and using a 0.1uF Multicap PPMFX to shunt noise to ground around the VR tubes. VR tubes are fed from a cascode CCS. Worked like a charm with no oscillation detectable on my scope.
Old 19th June 2012, 03:30 PM   #6
rongon is offline rongon  United States
rongon's Avatar
When you install a voltage divider from B+ to lift the heaters 40V to 60V above ground, doesn't that act as a bleeder resistor? Provides a discharge path through the two resistors to ground... No?
If so, there's killing two birds with one stone.
choke input power supply vitalstates Tubes / Valves 10 24th February 2012 01:03 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
bleeder resistor for ZenV4 power supply; and ancllary matters Zapped Pass Labs 13 24th September 2003 04:02 AM
Choke input Power Supply NickC Solid State 4 6th November 2002 07:41 PM
Copyright 1999-2017 diyAudio
