Old 18th June 2012, 03:44 PM   #1
Default Large tube anode connections caps.
Hello all...
I just waned to ask the forum if anyone knows of 20mm ID anode cap connections made of ceramic material. I need them for a gu81m project. I tried machining out of teflon but the result is well...less than ideal from an aesthetic point of view. I have some large anode caps but are less than 20mm. I thought of drilling a larger hole (20mm) but the cost of a good drill bit is substancial. If the idea doesn't fly I will have thrown away some cash.
basically even larger than the MCD series
If anyone could help I'd be very grateful
Thanks!
Old 19th June 2012, 06:07 AM   #2
ktuuri is offline ktuuri  Canada
Does it have to be Ceramic, I may have some spare Bakelite ones by AMPHENOL
NOS new in box. They will take the heat, I have used them with 869B Rectifiers.
Old 19th June 2012, 06:35 AM   #3
Thanks! no... Bakelite is fine. I need 4 of them at least and the anode connection is 20mm OD.
Inviato dal mio GT-I9001 con Tapatalk 2
Old 2nd July 2012, 09:03 PM   #4
I sent you a private message , check your inbox.
Old 2nd July 2012, 09:36 PM   #5
Replied
old style anode/grid caps lochness Tubes / Valves 1 11th July 2008 02:56 AM
E1148,CV6-How do you distinguish the anode/grid caps? protos Tubes / Valves 1 6th February 2008 04:47 PM
Re-attaching anode cap to 805 or 811A tube Jim Ricketts Tubes / Valves 5 7th June 2006 01:39 PM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Not connecting grids/anode can hurt tube? Redemption Tubes / Valves 6 14th January 2004 11:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
