#11 |
Yes it does make sense but if I do that the maximum current is about 240+ mA!!
So if the quiscient current is 80 mA the Q-point is not at the middle... right? and if this is right why does it happend? I think that in class A amplifiers the Q-point must be at the middle.. |
#12 |
If your bias point is with the current at 80mA then the current can swing plus / minus 80mA maximum (and in reality a bit less than that). So the peak current flow would be just under 160mA.
I think you assumed that the grid would go to 0 volts. To swing the current from 0 to 160mA the grid will not need to go that far - with a 2.5k load line biased for 80mA idle, it would go no more positive than about -30 volts for 160mA current. If you do take the grid more positive than -30 then you will simply introduce lots of distortion since the bias point would then not be at the middle of the current swing. Last edited by 12E1; 22nd June 2012 at 11:31 PM. |
#13 |
Ok I see what you mean.. But how can I be sure that the grid voltage wil not reach 0 or -10 volts?
#14 |
anyone??
#15 | |
| Newbie- Tube Testing RF Amp tube | jsternmd | Tubes / Valves | 0 | 25th October 2011 05:44 PM |
| Some general tube questions from a Tube newbie !! | Minion | Tubes / Valves | 11 | 6th March 2010 01:38 AM |
| New 300B PP amp completed, phase shift questions | zigzagflux | Tubes / Valves | 118 | 2nd May 2009 10:01 AM |
| Couple of (newbie) tube questions... | JoshK | Tubes / Valves | 6 | 13th December 2005 04:30 AM |
| What are terminal 1 & 4 of 300B tube | andy2 | Tubes / Valves | 45 | 24th January 2005 09:28 PM |
