newbie questions about 300B tube amp
Old 17th June 2012, 11:17 PM   #1
greg_e46 is offline greg_e46  Greece
Default newbie questions about 300B tube amp
Hi everyone.
I decided to built this tube amp 300B Mk1 Tube Amplifier but before I do it I have some questions about the design that I want to solve before I try it.
I've read some things about tubes and DHT tubes but I find it hard to understand some things.
1. If someone gives me the voltages of the anode, cathode etc. I can find everything easily. But if I want to design a tube amp like this I don't know where to start. I would like someone to explain what way is better to bias the tubes and what specifications of the tubes give me the voltages or everything else that I need. In other words I would like to know how can I use the datasheets when I want to design something because I am a llitle confused
2. I also find it hard to understand the combination of the 50Ω resistor and the 880Ω resistor and how this thing gives the 70 V of the cathode (I've read in other posts that the cathode operates about 70 volts)
And at last I think I must apologize for my bad English
Old 17th June 2012, 11:33 PM   #2
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Originally Posted by greg_e46 View Post
Hi everyone.
Well yours is a long way from the worst I've seen on this forum; no need to apologise!
Since you can write as well as you have in English, I suggest you buy a copy of Valve Amplifiers by Morgan Jones; this book is an excellent introduction to the principles of designing valve amplifiers.
As for your second question, first the 50 ohm is a potentiometer across the filament terminals of the 300B; it is known as a hum balance or "humbucker" pot. When directly heated valves such as 300B are heated from an A.C. source hum can be induced owing to resistance variations in the filament. Adjusting the hum balance pot compensates for this effect. As the valve ages, further adjustment may become necessary.
70V at the cathode with 880 ohms is a simple application of Ohm's law where
V/R=I or V=IR where the voltage in a circuit bears a direct relationship to the resistance of the circuit and the current flowing. So in your example, divide 70V by 880 ohms = 0.0795 - say 0.080A = 80 milliamps, the current flowing through the 300B.
Paul
Plug them in and light them up
Old 17th June 2012, 11:54 PM   #3
thank you for your quick reply.. so is 80mA good for this tube?
Old 18th June 2012, 01:24 AM   #4
Eli Duttman is offline Eli Duttman  United States
Learn to use the resources of the WWW to get data about various tubes. This time, I'll point you to a chart of 300B operating condition sets. Look here.
Eli D.
Old 18th June 2012, 03:43 PM   #5
7N7's Avatar
You are most welcome.
As for your question, I expect you have read Eli's reply with its very useful attachment.
Paul
Old 18th June 2012, 05:34 PM   #6
costis_n is offline costis_n  Greece
There are specific things that do not look "right" in this design, but these are finer points that can be addressed later, after you "get" the basic ideas.
Old 19th June 2012, 08:22 AM   #7
andyjevans is offline andyjevans  United Kingdom
I'd strongly recommend building this in a chassis with PLENTY of room in it. If this is going to be you "experimental" amp, leave room for improvements. An interstage transformer would be an instant improvement. There are also variations on the first stage like the 3a5 circuit from Rod Coleman on a recent 3a5 thread. You might also consider having the PSU in a different box so you only have DC in the signal chassis.
Have you chosen an output transformer? If you have a circuit that runs the 300b at 80mA, then you need an output transformer that is gapped for 80mA, or preferably slightly more. If you choose to buy an OPT gapped for 60mA, for example, you then have to change the cathode resistor on the 300b to run it at 60mA, or 50mA - use Ohm's law as 7N7 states. And yes - buy Morgan's book and read basic principles.
Andy
Old 19th June 2012, 10:51 PM   #8
tomchr is offline tomchr  Canada
tomchr's Avatar
The 300B is not an easy tube to drive.
I build a 300B driver a while back. The design is available here: 300B Driver : Neurochrome.com : : Audio
I've also dabbled in a DC coupled version:
DC coupled 300B idea - request for comments
Right now, I'm experimenting with an ECC99 common cathode stage with a cathode follower output. That works really well.
I tend to run the 300B rather hot - 400 V, 90 mA. Just shy of the 40 W max plate dissipation.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 22nd June 2012, 12:50 PM   #9
so after reading some articles I have more questions about the schematic.
I found EH 300B datasheet and tried to draw the load line and calculate the bias point. in the picture below I set the plate voltage at 360v (80% of Vplate max). With 880Ω resistor I have about 69volts dropped across cathode resistor and the bias current is ~80 mA. so the max current is 150mA. But if I draw the load line I don't have 2.5kΩ load as the schematic shows. So I suppose I am thinking-doing something wrong... Right?
Old 22nd June 2012, 08:02 PM   #10
tomchr's Avatar
The line that crosses the Y axis at 100 mA and the X axis at 250 V is a 2.5 kOhm load line. That one is drawn correctly. It does not, however, intersect the quiescent/bias point of the tube in your amp, hence, it is not the load line as seen by the tube. Draw a line that is parallel to your 2.5 kOhm load line that goes through the quiescent point. This load line will also be a 2.5 kOhm load line (as it's parallel to the first 2.5 kOhm line you drew) but it goes through the Q point, hence, will be the load line for the output tube.
Does this make sense?
~Tom
newbie questions about 300B tube ampHide this!Advertise here!
Newbie- Tube Testing RF Amp tube jsternmd Tubes / Valves 0 25th October 2011 06:44 PM
Some general tube questions from a Tube newbie !! Minion Tubes / Valves 11 6th March 2010 02:38 AM
New 300B PP amp completed, phase shift questions zigzagflux Tubes / Valves 118 2nd May 2009 11:01 AM
Couple of (newbie) tube questions... JoshK Tubes / Valves 6 13th December 2005 05:30 AM
What are terminal 1 & 4 of 300B tube andy2 Tubes / Valves 45 24th January 2005 10:28 PM
Copyright ©1999-2017 diyAudio
