EL84 SE advice for a beginner EL84 SE advice for a beginner - Page 7 - diyAudio
Old 5th January 2013, 07:44 PM   #61
Soonerorlater is offline Soonerorlater  United Kingdom
Soonerorlater's Avatar
Duncan's power supply simulator is very good for tailoring your power supply down to the desired B+.
Download
When white moths were on the wing,
moth-like stars were flickering out,
Old 5th January 2013, 08:18 PM   #62
tuhkam is offline tuhkam  Estonia
This is how the voltages measure right now!
Old 5th January 2013, 08:28 PM   #63
Oh, I completely ignored that I have a high value voltage devider (470k+22k) in the B+ supply. It goes from C2 to ground. It powers the on/off indicator LED.
Not sure if it could contribute to the overheating.
Thanks Soonerorlater, it is a very useful program.
I would need to change the choke to get the voltages up a bit. Would this lighten the burden on the PT?
Experiments with smaller chokes resulted usually in increased hum.
Old 5th January 2013, 10:18 PM   #64
A useful way to bleed your caps.
A choke of 5-10 H rated at about 100mA would be my choice.
Choosing a choke with a maximum dc resistance of less than 150r should run cooler than your 500r.
Also for good measure check capacitor C2 is not excessively hot ( again a relative thing ). Inspect for bulging of the body or top.
Old 6th January 2013, 02:04 AM   #65
djgibson51 is offline djgibson51  New Zealand
I agree with vinylkid. 220u for C2 is sucking big current pulses thro the PT.
Old 6th January 2013, 07:58 AM   #66
Thanks for advice guys! Now I have some things to try.
The C2 is doing ok (no overheating or bulging yet), but I agree 220uF is rather large. I have some 68uF and 47uF I can use.
Old 6th January 2013, 08:16 AM   #67
rvrazvan is offline rvrazvan  Romania
rvrazvan's Avatar
68uf and chokes!
Old 6th January 2013, 08:39 PM   #68
Here's a rough sim in Duncan giving you similar operating voltages.
Playing around with standard values of C1 can be very informative.
Old 7th January 2013, 08:06 AM   #69
Lowering the Caps on both sides of the choke to 100u, and the choke itselt to a 330ohm version helped a lot. Now the PT heats up much less.
EL84 SE advice for a beginnerHide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
Really low parts could el84 pp design for a beginner? nightanole Tubes / Valves 17 28th March 2011 12:20 PM
Advice for a beginner please.. Knoffers Tubes / Valves 2 6th December 2010 02:33 PM
Absolute beginner- advice please H Fiddlefinger Introductions 1 9th June 2008 02:40 PM
Beginner needs advice on LM4766 Aidan135711 Chip Amps 3 17th February 2008 11:23 AM
Copyright ©1999-2017 diyAudio
