Re: Buffer with tube PCC88 - diyAudio
Old 17th June 2012, 05:17 PM   #1
formula 22's Avatar
Lightbulb Re: Buffer with tube PCC88
Hello all!
I need schematic a stereo buffer with Tube/Valve PCC88, where the input resistance will be 1Mohm, and with an output <1Kohm
Thank you for your cooperation.
Old 17th June 2012, 05:33 PM   #2
artosalo's Avatar
How many tubes may be used ?
With one PCC88 it is most likely impossible.
Old 17th June 2012, 05:49 PM   #3
SY's Avatar
Why? gm is likely 8mA/V, so source impedance of a cathode follower will be ~125R plus perhaps another 100R for a cathode stopper.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th June 2012, 06:27 PM   #4
artosalo's Avatar
True, if no gain is required.
Old 17th June 2012, 06:35 PM   #5
formula 22's Avatar
Why not? percent of it is double triode.
Here's how I conceived the schematic. I'd say that the values ​​that are components of the input = 1Mohm and output <1Kohm ( for frequency 30Hz ...20kHz to + / -0,5dB), with a gain of about 0,95 dB!
thanks
Old 17th June 2012, 06:51 PM   #6
artosalo's Avatar
Your circuit is fully OK if gain just below 1 is sufficient.
The following component values will give good operation: R1 = 1 M, R2 = 1k, R3 = 470, R4 = 10 k, R5 = 1k, C3 = 100 uF, C4 = 10 uF, R5 = 100 k, C1 = 22nF.
But what will be your load impedance and required output voltage ?
Old 17th June 2012, 07:11 PM   #7
formula 22's Avatar
artosalo thank you for your prompt response. After this comes the buffer Po=60W/8R audio amplifier with an input voltage Uin(max) = 1V; Rin = 47k.
If someone has something else to add some of this buffer is welcome, ...
thanks and cheers!
P.S.
Sam should now look like this:
Now please offer some quality power supply for the buffer ..
Old 18th June 2012, 01:53 AM   #8
rongon is offline rongon  United States
rongon's Avatar
Do you only have +90V available for the B+ supply? That's not much for this type of tube (or any tube, for that matter).
I'd aim for +90V between the PCC88's plate and cathode. The 10k cathode load resistor would drop 90V across it if you have 9mA current through the tube, which is not excessive at all for a 6DJ8/ECC88 class of tube. Gm goes up with increased current through the tube, which is good for a cathode follower (reduces output Z). PCC88 has max plate dissipation of 1.8W. Ua of 90V * Ia of .009A = 0.81W, so you would still be well within that limit.
You might want to consider using something like a +180V supply.
Old 18th June 2012, 06:16 AM   #9
formula 22's Avatar
[QUOTE=rongon;3063443]Do you only have +90V available for the B+ supply? That's not much for this type of tube (or any tube, for that matter).
OK, if I go with the power supply B+(+Ua)=+180V, which should have value resistors in the schematic (P1, R1, R2, R3, R4, R5, R6)?
thank you!
Old 18th June 2012, 06:53 AM   #10
artosalo's Avatar
You do not need to change anything. With 180 V supply voltage the performance is just better.
Tube preamplifier with PCC88 r!sc! Tubes / Valves 37 17th November 2012 01:45 PM
Hibryd amplifier with tube/valve ECC88 (PCC88) and chipamp LM1875 formula 22 Tubes / Valves 18 14th July 2012 12:27 PM
Power supply for tube preamplifier with PCC88 formula 22 Tubes / Valves 0 16th April 2012 08:03 AM
Re: Tube Line gain stage with pcc88 or ecc82 formula 22 Tubes / Valves 22 13th April 2012 08:16 AM
Pcc88 leo529 Tubes / Valves 17 22nd June 2006 05:06 AM
Copyright 1999-2017 diyAudio
