Transformer impedance calcs from windings
Old 17th June 2012, 04:08 PM   #1
composition4 is offline composition4  Australia
Default Transformer impedance calcs from windings
Is anyone very handy with the theory and calculations behind transformer windings, specifically an output transformer for an amp? *I'd love to know the primary side reflected impedance (or impedance ratio) for the following transformer if anyone is knowledgeable enough to know how to calculate it from the winding information on the second picture. *I wouldn't really know where to start!
Winding 1 - 2 layers (37 + 37 winds), wire diameter 1mm.
Winding 2 - 2 layers (94 + 110 winds), wire diameter 0.3mm.
Winding 3 - 7 layers (each 118 winds), wire diameter 0.3mm.
Winding 4 - 1 layer (43 winds), wire diameter 0.9mm.
Winding 5 - 7 layers (each 118 winds), wire diameter 0.3mm.
Winding 6 - 2 layers (110 + 94 winds), wire diameter 0.3mm.
Winding 7 - 2 layers (37 + 37 winds), wire diameter 1mm.
Thanks!
Jonathan
Old 17th June 2012, 05:04 PM   #2
Funker is offline Funker  Germany
Thanks!
Jonathan
Hi Jonathan,
the impedance ratio is square of the winding ratio.
zprim/ zsec= wprim/wsec
example:
A given opt has 4000 turns plate to plate. The speaker winding has 200turns .
The speaker impedance is assumed 8 Ohms. What impedance reflects to the primary winding?
Zprim= (wprim/wsec) x Zsec = (4000turns/200turns ) x 8 ohms = 3200 Ohms.
Now you can calculate your xmfr.
73
Wolfgang
Ground your devices before they ground you
Old 17th June 2012, 08:09 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Apply an AC voltage to the primary (blue to orange on your trafo) for example by connecting it to a variac and slowly dialing up the voltage. Measure the AC voltage on the secondary (black-green and black-yellow).
The turns ratio is then N = Vprimary/Vsecondary.
The impedance is transformed by the square of the turns ratio. I.e. Zprimary = Zsecondary*N^2.
In your case, windings 1 and 7 are in parallel on the secondary. The primary is windings 2+3+5+6. So the turns ratio for the black-green secondary tap should be N = 2060/74 = 27.84. For the black-yellow secondary, N = 2060/(74+43) = 17.61.
If you load black-yellow with 8 ohms, you should get Zprimary = 8*17.61^2 = 2480 ohm. Loading the black-green secondary with 8 ohms yields, Zprimary = 8*27.84^2 = 6200 ohm.
I'm guessing one secondary is a speaker winding and the other a feedback winding. 6200 ohm... Is this for a 6L6 amp by any chance?
It looks like the taps on the primary are at 20 % of the winding rather than the more common 40 % UL taps.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 18th June 2012, 02:01 PM   #4
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Rather than using a Variac that most people don't have. Use a little wall-wart AC output power supply/transformer. A wall-wart with an output of about 10 Volts AC would be great. Then use Tom's math.
Kevin
Transformer impedance calcs from windingsHide this!Advertise here!
Torodial transformer - help with secondary windings pvh1987 Power Supplies 2 2nd October 2011 06:45 PM
Which impedance do I choose for xover calcs? skeptic43 Multi-Way 4 15th October 2009 12:43 AM
Transformer Windings impsick Chip Amps 6 2nd February 2007 11:00 AM
transformer primary windings Q AndrewT Power Supplies 6 28th October 2006 11:51 AM
Transformer windings identifications - how to get it? Alfetta87 Solid State 7 21st February 2005 04:01 PM
