Anyone came across AirTight ATM-2 schematic? - diyAudio
Old 17th June 2012, 11:06 AM   #1
Default Anyone came across AirTight ATM-2 schematic?
Hi
Probably one of the best KT88 integrated Push-Pull amplifiers , what's so special about the circuit?
It uses 2x ecc83 ,2 x ecc82 ,2 x 12BH7A , Tamura OPT's
I have built few incarnations of KT88 Push-Pull transformer interstage coupled , with input transformer splitting , used different input tubes , not bad Lundahl transformers and final result was resulting in sound much worse than simple PP El34 , srpp ecc83 , ecc81 LTP.
I wonder if Transformer coupling is any good?
Old 17th June 2012, 09:44 PM   #2
soulmerchant's Avatar
Why not show your schematic on the 'sound much worse' amplifier? You will probably get some advise.
I don't do transformer coupling because I haven't yet felt the need to.
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 05:51 PM
AirTight ATC-2 Preamp Pictures Algar_emi Analog Line Level 15 18th April 2012 08:38 AM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 07:52 PM
Is the Bash 300 plate amp airtight? preiter Subwoofers 1 17th July 2006 05:50 PM
airtight atm-1 ben goh Tubes / Valves 0 14th March 2003 02:06 AM
Copyright 1999-2017 diyAudio
