PSU capacitor max.voltage question - diyAudio
Old 13th October 2003, 12:02 PM   #1
Default PSU capacitor max.voltage question
Hello,
Is it safe to use 400v rated capacitors in PSU like below??? - according to my knowledge the maximum voltage on caps will be less than 360V.
Image of the PSU:
Old 13th October 2003, 12:24 PM   #2
I don't have data of this power transformer but secondary for B+ are at about 250-260V.
Any help?
Old 13th October 2003, 12:41 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Assuming a 0-260VAC secundary you'll be perfectly safe.
Frank
Old 13th October 2003, 12:43 PM   #4
Jennice is offline Jennice  Denmark
Hi...
I've never worked with tupe audio, but as I see it, there's a potential risk for the capacítor located between the bridge rectifier and the inductor. Ripple voltage peaks will be much higher there than after the inductor. Just a consideration. Maybe a computer simulation could solve the mystery.
anyone up for the task?
Jennice.
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 13th October 2003, 01:06 PM   #5
So maybe the good solution is to have 450V rated cap before choke and after the choke - 400V rated caps?
Thx. for answers....
Old 13th October 2003, 02:23 PM   #6
peranders's Avatar
Is this only an idea or have you practical experience of it?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE If the interest is big enough there will be a group buy
Old 14th October 2003, 12:31 AM   #7
fdegrove's Avatar
I'd suggest you guys fight Viking batlles outside the classroom/forum?
Per-Anders, I know what you mean, but do we have to bite other people's head of?
Please?
Frank
Old 14th October 2003, 12:37 AM   #8
badman is offline badman  United States
badman's Avatar
Default cap voltage
Electrolytic capacitors operate best close to their rated voltage. If B+ is no more than 250-260, then 300V caps would be appropo, and perform better than 400-450V caps. If you're worried about post rectifier ripple, use a HV poly after the rectifier, and electrolytics after the inductors.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 14th October 2003, 12:50 AM   #9
fdegrove's Avatar
Yes...But what about safety margins?
Now do your sims at what cap values really are at operating voltages and feel as smug as you think you are.
Feeling kinda Freddish,
Frank
Old 14th October 2003, 04:23 AM   #10
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Don't forget that caps are rated for a good bit of overvoltage too. And I personally have ran a 350V rated cap (60s-era octal based, no less) at 450V with no ill effects
*Don't do that on purpose BTW*
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Capacitor Voltage Rating Question Trout Tubes / Valves 11 5th June 2009 06:49 PM
Amplifier main capacitor replacement - voltage question Tino Pass Labs 22 12th November 2008 04:27 PM
Coupling capacitor voltage question woodman Solid State 19 13th June 2008 09:51 PM
Capacitor voltage ifrythings Power Supplies 13 19th April 2006 11:18 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
