My poor man version of the Raven Preamplifier.
Old 19th June 2012, 11:11 AM   #21
revintage is offline revintage
If currentbalance is OK you should either remove or short the cap, off course another thing if you later wish to balance currents electronically with a current mirror.
The cap serves no purpose as I see it, as this is a balanced design and NO LTP. Shorted no local feedback, open local feedback.
Old 19th June 2012, 11:19 AM   #22
piano3 is offline piano3  United Kingdom
I initially used 20uF in a similar circuit with low mu tubes and had a bit of a problem with record warps so you might start to see bass extension with your circuit at not much over 100uf assuming mu of 16 for 5687 and 100H(?) for the OPT primary.
My circuit had tails about 50 Mohms long
Old 19th June 2012, 09:59 PM   #23
Marginal bass-boost with 10u but it is there. It peaks at 70Hz by 0,2dB with some guesstimates of the inductance values.
Shorting the cap gives the best low end extension and is -1dB at ca 15Hz. The other to are -3dB at the same frequency. But as I say the inductances are guesswork with the primary at 100H.
So removing the cap is no option. Either substitute with a big enough or short it.
I anyway get indications of a very good design(apart from the cap).
Old 20th June 2012, 07:10 AM   #24
Shoog is offline Shoog
Shoog's Avatar
The cap will be increased. The whole cathode arrangement was a lash up to see how things would sound. Typically I have used a 1000uf back to back with 1000uf on all my other designs and this typically works well and is cheap (64V caps).
Shoog
Old 20th June 2012, 07:24 AM   #25
Short it=infinite cap. But from 470u it will not upset frequency-response.
Once again this is not a LTP. If you go for CCS or current mirror add a cap to each cathode to ground and no cap should between cathodes necessary. About the latter it might be a sonic benefit using your previous back to back arrangement, you decide.
Old 20th June 2012, 07:33 AM   #26
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
nothing wrong with LTP there
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th June 2012, 07:36 AM   #27
This isnt a LTP! Its a balanced output stage using a smart input transformer arrangement with a twist. LTP is one input shorted and signal to the other.
Old 20th June 2012, 07:41 AM   #28
Zen Mod's Avatar
yes , you can use both
but I'm saying that is nothing wrong if one is using LTP stage after xformer
especially this xformer
Old 20th June 2012, 07:49 AM   #29
Can use is one thing, Shoogs design is still balanced not LTP.
Old 20th June 2012, 07:52 AM   #30
Zen Mod's Avatar
sorry , current one , posted schmtc really isn't ;
but I commented basing on Shoog's plan to include current mirror in cathodes
then , with AC coupling between cathodes , that is enough LTP for me
My poor man version of the Raven Preamplifier.Hide this!Advertise here!
Poor mans WR125? rick57 Full Range 25 12th August 2014 04:46 PM
A poor man Feastrex ! FullRangeMan Full Range 53 31st October 2012 08:29 AM
The poor man SMPS mag Power Supplies 5 12th June 2010 11:44 PM
poor man reciever v1d9uy Solid State 4 6th January 2006 03:28 PM
Copyright ©1999-2017 diyAudio
