I built my first regulated DC supply for a 12B4 preamp. It uses the LM7812 and puts out a steady 12v without a load. When powering the heaters on one tube, everything is fine. However, it shuts down after a few seconds when I hook up the second tube. The 12B4 consumes about 300 mA per tube, and the 7812 is rated up to 1 amp when heatsinked (the regulator is bolted to the chassis in my build).
I'm confused Any help appreciated.
#2 |
The regulator takes about three volts to operate stable. Can your power supply deliver 15 volts at 0.6A?
jaap |
#3 |
#4 |
Measure the input voltage to the 7812. Check that the PSU is actually delivering what it says it can.
How good is the heatsinking? Did you deburr the mounting hole? Is there good thermal contact between the regulator and the chassis? |
#5 | |
I'll go back and deburr that hole. Thought I'd cleaned it up pretty well and had the regulator mounted tightly to the chassis, but I'll check again. |
#6 |
are you sure the regulator is not going into short circuit mode ? the cold resistance of tubes is quite low .
7812 is a cheap regulator buy a second and use one per heater use the decoupling caps like in the datasheet add a diode from the ground pin to ground to lift the 7812 to 12.6 volts for correct application and ofcourse less dissipation
#7 | |
overvoltage or overdissipation kicking in or both ![]() Edit better use a 317 its more temp stable constant current works a charm Last edited by v4lve lover; 15th June 2012 at 09:11 PM. |
#8 |
38V might be enough to cause thermal shutdown, as well as being over spec anyway. Read the device datasheet. Do a rough estimate thermal calculation.
#9 |
There are many versions of 7812 from different manufacturers. A quick scan of a few datasheets shows some have a maximum input voltage as low as 27 volts, others up to 35. At 38 volts you are likely to have some problems. Some versions will also limit current just because the input to output voltage drop is high (even though the regulator may not be overheating at that time).
#10 |
Thanks for the help, gents. My next step is to find out why I'm getting 38v out of a 24v transformer (Triad VPS24-1000).
| DC Heater Caps | Bengali | Tubes / Valves | 3 | 24th September 2011 11:29 AM |
| dc heater supply help | milen007 | Tubes / Valves | 17 | 21st February 2009 07:42 AM |
| DC Heater Voltage | Bengali | Tubes / Valves | 9 | 2nd February 2009 04:19 AM |
| referencing DC heater to B+ | jarthel | Tubes / Valves | 4 | 28th March 2007 02:43 AM |
| Diode for DC heater | dsavitsk | Tubes / Valves | 16 | 2nd January 2007 04:13 AM |
