Loudness controls
Loudness controls
Old 14th June 2012, 03:46 PM   #1
M Gregg is offline M Gregg  England
Default Loudness controls
I thought,
It would be interesting if people could add links or circuits for Loudness controls for tube circuits..I noticed some people still use them..
I guess it would be interesting for comments as to the the use<<or are they worth using??
If they are worth using which topology is the preferred and why?? (Passive, active, tapped volume,)
M. Gregg
Old 14th June 2012, 04:54 PM   #2
Other linked information,
Its old but still relevant..
M. Gregg
Old 14th June 2012, 05:16 PM   #3
Just for interest...
Old 14th June 2012, 09:11 PM   #4
indianajo is offline indianajo  United States
indianajo's Avatar
I lost my loudness control when the volume control pot wore out on my dynakit PAS2 preamp. I liked the loudness function fine. I had a **** of a time finding a 250 k log stereo pot, much less one with a loudness section, too. I modded a disco mixer to replace the preamp before I found a pot. The replacement pot I got from stereo cost cutters in 1980 was a dynaco reject, the shaft was too tight. It had to be turned by vice-grip pliers. Bet this new pot doesn't last 19 years, either. Mil-spec copy analog parts are as dead as the dodo bird. I was laughing all through college in the seventies, everybody in the dorm had these import receivers that the volume and tone controls were bad in the second or third year. My best friend's Heathkit developed the same problem. Meanwhile the dynaco ST35's in the college library listening rooms just plowed on, impervious to constant use. I was lucky to find a used set in 1970, just needed new e-caps and rectifier tubes.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 3rd July 2012, 06:17 AM   #5
DualTriode is offline DualTriode  United States
Smile Loudness controls
Hello All,
Heaven forbid line level equalization controls.
In the old days it was built into my PAS 2. Then we read about the “recommended” mods that removed the tone controls and loudness controls.
Now I am scratching my head over baffle step correction for my home brew speakers. In the old days this is when I would kick in the loudness control on the Pas 2.
Decision made, I am pulling the original old PAS 2 off the shelf to recall what tone and loudness controls are about.
All for Fun
DT
Old 3rd July 2012, 08:00 AM   #6
flatheadmurre is offline flatheadmurre  Sweden
I have a bunch of piher 50x2 with "bass tap" you can have if you want.
Wasn´t it called hearing compensated volume control or something like that ?
Old 3rd July 2012, 12:25 PM   #7
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I never found much use for the tone control, but when I was in college I used the loudness control when I turned the stereo down for background music when I was studying.
Any more I play the system loud enough that the it is not necessary.
Nice Articles.
Old 3rd July 2012, 03:48 PM   #8
smbrown is offline smbrown  United States
smbrown's Avatar
I have often thought that baffle step correction was essentially like a "fixed" loudness control. Personally, I like using a loudness control for low level listening. I'd add one to my existing preamp if I had the correct parts to do it.
Old 5th July 2012, 07:44 AM   #9
Fidelius is offline Fidelius  Italy
Fidelius's Avatar
The Yamaha Natural Sound series solid-state amplifiers had a separate loudness control next to the volume. One set the volume to comfortable levels, then used
the loudness knob to reduce the sound without losing the lows and highs.
Can't think why this circuit could not be used with a valve circuit. Also, it does
not require a tapped-track potentiometer.
Loudness controlsHide this!Advertise here!
Loudness Wars again SY Music 9 6th July 2015 07:31 AM
Loudness experiences? Skorpio Solid State 24 27th July 2012 05:58 AM
The Loudness button 2litre Everything Else 15 25th November 2006 11:04 AM
Loudness switch Brushpilot Analogue Source 0 17th July 2004 02:59 PM
