Converting Eico HF-81 to a simple PP EL84 (pics incl.) - Page 3 - diyAudio
Old 14th June 2012, 11:07 PM   #21
cjkpkg is offline cjkpkg  United States
Here is my build from the Tubecad Blog circuit
Additions are:
CCS on the EL84 cathodes
Red LED on the input tube cathodes
Old 15th June 2012, 12:15 AM   #22
The OP stated the choke was OK. No choke is shown in the HF-81 schematic. Is the power trafo intact?
The idea of switching to 12DW7s is very good. However, there are plenty of sockets available on the "carcass". So, use system # 1 of a 12AX7 (voltage amp) and a 12BH7 (splitter) in a channel and system 2 of the same 2 types in the 2nd channel. When tubes wear out, flip flop. The 'U7 triode makes an acceptable "concertina" phase splitter, but it is out classed by the more linear 12BH7.
Eli D.
Old 15th June 2012, 01:19 AM   #23
ArtG is offline ArtG  United States
Eli-Would the 12BH7 be a "direct swap", or would value changes be necessary to the plate and cathode resistors, for best performance?
Old 15th June 2012, 01:34 AM   #24
Old 15th June 2012, 01:41 AM   #25
The 12BH7 triode is close enough to the 12AU7 triode to permit direct insertion (assuming the doubled heater draw is not problematic), but tweaking things to maximize performance is a DIYer's prerogative.
Eli D.
Old 15th June 2012, 06:04 AM   #26
Banned
can original schematic of HF-81 be modified as following??
no phono stage
no FM/AM input
no pre out
no Mic in
no tone control
no input selector (single input)
no function selector
the only remaining sections are line stage + amplification
Old 15th June 2012, 07:28 AM   #27
I'd turn it into a guitar amp.
Old 15th June 2012, 02:06 PM   #28
directdriver's Avatar
Originally Posted by ARIYAHOOR View Post
can original schematic of HF-81 be modified as following?? no phono stage, no FM/AM input, no pre out, no Mic in, no tone control, no input selector (single input), no function selector. the only remaining sections are line stage + amplification
Before you ask all these questions and go any further, ask yourself if you know how to read a schematic or at least understand the idea of signal path. Because I just posted a schematic that's exactly as described above! Check post #20. Bypassing unneeded functions in an integrated amp is really easy... you just don't connect the wires to them.
Old 15th June 2012, 05:04 PM   #29
Banned
Oh for sure... I can read schematics but I'm not so familiar with tube-based ones... I used to fix black and white T.Vs... one way or the other I could read the scema and follow the signal path... the point is that I didn't know if the circuit is Ok if I disconnect any section or not... I'll try to omit phono stage section at embryo stage
Old 16th June 2012, 12:01 AM   #30
Repeat!! Is the power trafo intact?
Eli D.
Eico Hf-81 Integrated Amplifier orly40 Tubes / Valves 3 7th February 2011 01:44 PM
Eico HF-81 modification opinion renarobert Tubes / Valves 7 21st May 2010 02:31 PM
help w/ Eico hf-81 paulnparis Tubes / Valves 3 29th August 2009 12:57 PM
Eico HF-81 OPT specs jmillerdoc Tubes / Valves 1 28th August 2009 09:15 PM
WTB: Eico HF-81 mrdon Swap Meet 0 20th October 2005 02:02 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
