#11 | |
jeff |
#12 |
frugal-phile(tm)
I consider these the 3 usual candidates. We have an El Cheapo variant with triode strapped EL84 (no feedback) that is VERY good. If you want more power, Baby Huey adds RH-style Schade feedback. I like the LTP front end.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 |
#14 |
No ultralinear taps on output transformers rules out Baby Huey.
#15 |
... why not something like Tubelabs Simple P-P with 12AT7 in front (input gain stage - concertina). Enough gain to use also gFB as George does in pentode EL84 configuration ...
#16 |
#17 |
Banned
Eico HF-81 schema is so complicated with lots of In/out terminals... I just want to make it easy... I know transformers of Eico HF-81 are magical so I used them to build a new amp... all tubes are original (Mullard) I'll use them
#18 | ||
jeff |
#20 |
You can try this, easiest and only amp section and keeping the volume control:
![]() If you want to include part of the line stage, which I think it's where the "magic" is and more gain. Purists will disagree but you can always compare the two. ![]() Anyway, I don't see how other EL84 circuits can be simpler.... Another option is to simply copy the HF-86, which is essentially the pure amp version of the HF-86. The driver, however, uses the 7247/12DW7, which is half 12AX7 half 12AU7. You can see the similarity between the two.
| Eico Hf-81 Integrated Amplifier | orly40 | Tubes / Valves | 3 | 7th February 2011 01:44 PM |
| Eico HF-81 modification opinion | renarobert | Tubes / Valves | 7 | 21st May 2010 02:31 PM |
| help w/ Eico hf-81 | paulnparis | Tubes / Valves | 3 | 29th August 2009 12:57 PM |
| Eico HF-81 OPT specs | jmillerdoc | Tubes / Valves | 1 | 28th August 2009 09:15 PM |
| WTB: Eico HF-81 | mrdon | Swap Meet | 0 | 20th October 2005 02:02 AM |
